126,000 mile BONE STOCK engine compression test results - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-24-2012, 06:11 PM   #1 (permalink)
csufdrew's Avatar
Member Number: 1843
Default 126,000 mile BONE STOCK engine compression test results
160-162 across the board.fully warmed up engine and throttle open.
How does that rank? I do have a slight leak from the valve cover gasket in cylinders 2-3. I'm getting my timing belt changed next week and also gonna do the valve cover gasket
Stage 3 turbo / E85 / SCT PRP
12.133 @ 120.490 MPH
csufdrew is offline   Reply With Quote
Old 11-24-2012, 06:20 PM   #2 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Thats pretty good for those kinda miles. lol
Diablo CMR tuner ~Dan~
310HP 436TQ
2004 Eblue Neon SRT4: E85 5558 Built motor
XXXHP XXXTQ
Old 11-24-2012, 06:23 PM   #3 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
hell ya, im at 70k with 150 across....
Old 11-24-2012, 06:40 PM   #4 (permalink)
John203's Avatar
Member Number: 78805
last time i checked mine , 65k miles 172-175psi across the board . Car was beaten daily s3 , then big turbo at 50k
Dcr Option A + Cncport Street Storm head + DBB 6262 =
John203 is offline   Reply With Quote
Old 11-24-2012, 07:28 PM   #5 (permalink)
ziggo0's Avatar
Member Number: 63759
Did mine right at 100k. 165 across the board. Leak down was 7% in each cylinder.
Stone White 05 - Built Motor, Built Head, e85 & 75lbs/min - coming soon
Old 11-24-2012, 07:53 PM   #6 (permalink)
csufdrew's Avatar
Member Number: 1843
What tools are needed for a leakdown test?
Old 11-24-2012, 08:01 PM   #7 (permalink)
SRTFORUM Moderator
Advans's Avatar
Member Number: 12791
Compressor, leak down testing kit...think that's it. Been a while.
And your numbers are.
Advans is offline   Reply With Quote
Old 11-24-2012, 08:05 PM   #8 (permalink)
csufdrew's Avatar
Member Number: 1843
Thx advans... its been modded since day 1. S3 turbo since 40k miles and beat on it daily...oil every 6-8k miles with Mobil 1.
Old 11-24-2012, 08:08 PM   #9 (permalink)
khaoSrt4's Avatar
Member Number: 62825
That's really good with those #s
khaoSrt4 is online now   Reply With Quote
Old 11-25-2012, 11:13 AM   #10 (permalink)
srtmike04's Avatar
Member Number: 41861
^^ill give you a
srtmike04 is offline   Reply With Quote
Old 11-25-2012, 11:24 AM   #11 (permalink)
Member Number: 35677
Default coolant and oil
csufdrew - there's your reason for a healthy engine right there - oil changes and no overheating I'll bet
ValleyRacer is offline   Reply With Quote
Old 11-25-2012, 11:52 AM   #12 (permalink)
ziggo0's Avatar
This is why I tell everyone general maintenance and fixing shit that's broke goes a very long way.
Old 11-25-2012, 11:55 AM   #13 (permalink)
Member Number: 11361
My numbers were about the same
Worth checking turbo shaft play
AG Free
Build Thread:http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline   Reply With Quote
Old 11-25-2012, 12:02 PM   #14 (permalink)
Default Gospel truth!
If you can just get people you know or friends, etc - to just get the oil changed - they'll end up saving so much time, money and headaches.
Even sending people to Jiffy Lube (or similar) is better than no oil changes. The J-team idiots will often check air filters and things - at least to prevent a disaster - but otherwise they techs are often full of horsesh**.
And when you tell people about something, they can act on it or ignore it!
Old 11-25-2012, 04:00 PM   #15 (permalink)
csufdrew's Avatar
Member Number: 1843
Correct. Oil analysis actually says to try 9-10k between changes. Also have had 180* thermostat for a long time.
