Old 03-23-2009, 03:55 PM   #1 (permalink)
mikedero08's Avatar
Member Number: 71493
Default Spray out the engine bay?
Can I take a hose and safely clean up my engine bay without damaging anything?
mikedero08 is offline   Reply With Quote
Old 03-23-2009, 04:40 PM   #2 (permalink)
slickwillie's Avatar
Member Number: 47326
just did mine last night, just be careful around the fusebox and wires. I sprayed mine down with simple green and let it soak for about 5-10 min then sprayed it down but not at full force just enough to get the junk off
slickwillie is offline   Reply With Quote
Old 03-23-2009, 04:48 PM   #3 (permalink)
HWY*'s Avatar
Member Number: 65076
I hose my engine down about once a year w/ no ill effects what-so-ever. Be careful around your alternator as well. Simple green does a good job but I've also used etching mag cleaner on the rough cast aluminum IM & tranny case. Be sure to wet it down B4 applying solvents.
HWY* is offline   Reply With Quote
Old 03-23-2009, 04:52 PM   #4 (permalink)
D-ROK's Avatar
Member Number: 50159
go to the car wash ans use a pressure washer. It uses less water and will blow the crap out better. Just do quick bursts around the places you want to clean. Just be careful around electrical/alternator.
Drastic. & Assoc.
D-ROK is offline   Reply With Quote
Old 03-23-2009, 05:03 PM   #5 (permalink)
HWY*'s Avatar
This method does work very well, however, the owners of the u-spray-it car washes usually frown upon outside solvents. You also don't want to go spraying cold water on a hot motor. Keep that in mind while driving to the car wash. Don't race there!
Old 03-23-2009, 05:19 PM   #6 (permalink)
mikedero08's Avatar
Should I bag up my intake (short ram) or anything like that?
Old 03-23-2009, 05:22 PM   #7 (permalink)
HWY*'s Avatar
It's a good idea. IMO
Old 03-23-2009, 05:31 PM   #8 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (21)
You don't need to be careful around your alternator. Don't purposely get it soak and wet, but if you do, simply wait for it to dry out BEFORE you start your car.
The only thing I ever cover is my intake cover. I then spray absolutely everything with Simple Green, and I spray it very generously. I let it sit for 10-15 minutes, then I put the garden hose on a mist setting and spray everything off. The only time I will put it on a constant stream is when I angle it in the valve cover to get the suds out of where the spark plug wires are attached.
Old 03-28-2009, 05:39 AM   #9 (permalink)
my_little_srt's Avatar
Member Number: 41179
Trader Rating: (24)
Yes, use a plastic bag from wal mart or something similar...................
my_little_srt is offline   Reply With Quote
Old 03-28-2009, 11:24 AM   #10 (permalink)
rasp's Avatar
Trader Rating: (21)
Tin foil works well for anything like that. Conforms to the piece like a glove and keeps water off it it, too.
Old 03-28-2009, 01:38 PM   #11 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (21)
I always just pull my intake off and stick a rag or something of the sort in the turbo. and plug my valve cover vent. Spray mean green let it set for 5 minutes then spray if off. Then go crazy with tire shine and a sponge
Tuned By TDSAaron!!
Now Rocking a Delta 46
Old 03-28-2009, 01:40 PM   #12 (permalink)
Member Number: 36585
Trader Rating: (12)
i use a pressure washer with medium pressure nozzle, i use engine brite..
just-a-neon is offline   Reply With Quote
Old 03-30-2009, 06:20 PM   #13 (permalink)
DrRafy's Avatar
Member Number: 14422
Ok I use simple green, but I cover my Intake filter, battery, spark plug area, prevent spraying the alternator with water. I use a paintbrush just to clean around the engine bay to get the heavy stuff.
However, here is a web site that it specialized on detailing
Engine Cleaning & Detailing - Autopia.org
My SRT-4 Mods: Who Cares is Just a Neon
www.myspace.com/rafysoto
DrRafy is offline   Reply With Quote
Old 03-31-2009, 12:02 AM   #14 (permalink)
memphiselitez's Avatar
Member Number: 65236
wouldnt that get into the holes where the spark plugs are?
x2 on that one. its what i do
id love to see what your engine bay looks like. you aught to pm me some pics if you dont mind
2004 Black SRT-4
2008 Honda CBR1000RR Red/Black
memphiselitez is offline   Reply With Quote
Old 04-07-2009, 04:13 PM   #15 (permalink)
bachelorracing's Avatar
Member Number: 42144
The method I use works fine. Get some auto degreaser (mine is 50/50) and a pressure washer. Turn on the car and let it run. Spray on the degreaser and let sit for a min. You keep the engine on so the degreaser and heat up and do work. Use pressure washer on any setting and spray it down. our washer is set on high at all times. Take a skewer and a cloth to get the tight spots. Leave hood up and car running for ten mins. I use Black Magic Tire dressing for under the hood to get that killer shine. We detail cars for auctions and for show rooms everyday 7days a week. Just dont be stupid.
bachelorracing is offline   Reply With Quote
