Old 12-14-2007, 11:31 PM   #1 (permalink)
Member Number: 52407
Default price of quality paint job
What do you think a high quality paint job would run? One that is equal to or better than the factory paint job.
7055 is offline   Reply With Quote
Old 12-15-2007, 08:00 AM   #2 (permalink)
Mid-Atlantic Moderator
snkmug's Avatar
Member Number: 24604
Trader Rating: (46)
about 3-4 thousand dollars, needs to be wet sanded and buffed to get the peel out..........
snkmug is offline   Reply With Quote
Old 12-15-2007, 10:17 AM   #3 (permalink)
Slow_spool's Avatar
Member Number: 50382
it will varry alot pending on the shop that you go to, what color you want (red and black are the most expensive due to the pigments) and if you want any type of design which would require waiting longer for paint to cure to mask off for graphics. typically at wyotech we charge around $180 or so for sherwin williams paint and supplies to paint a car.
and we are taught that the factory paint jobs are not all that great, there are many variences in the color from car to car, and take a look at how much orange peel is in your paint job sometime..there is always orange peel in a factory paint job, if you want it can be taken out or sanded down just a little bit so that there is a little orange peel left when the car is buffed
Slow_spool is online now   Reply With Quote
Old 12-15-2007, 06:28 PM   #4 (permalink)
How long would it last, resist fading and all that?
Old 12-15-2007, 08:30 PM   #5 (permalink)
Slow_spool's Avatar
you get what you pay for, it will last longer then OEM if it is done right
Old 12-16-2007, 04:18 PM   #6 (permalink)
xzero's Avatar
Member Number: 50867
Trader Rating: (15)
Yeah just like everyone above me said factory paint jobs are poo and the whole car would definitely be wet sanded and buffed for a quality job.
03 SRT-4
xzero is offline   Reply With Quote
Old 12-16-2007, 04:34 PM   #7 (permalink)
bsbob's Avatar
Member Number: 5248
Trader Rating: (25)
the WET sanding is not so to remove the ORANGE PEEL but the other stuff like DIRT PARTICLES. no enviroment is DUST FREE, so these things are REMOVED from the finish by COLOR SANDING with 1500 to 2000 grit paper. this sanding LEVELS the orange peel plus imperfections in the sprayed finish. an average GOOD paint is between 3 and 4 thousand bucks, provided the same color. a color change is prolly another 750 to a grand for the jambs. BSBOB
bsbob is offline   Reply With Quote
Old 12-16-2007, 05:26 PM   #8 (permalink)
Slow_spool's Avatar
but you do wet sand to remove orange peel, no matter who is painting, and the paint gun, you are alwyas gona get orange peel in every paint job, and the good high quality paint jobs are wet sanded to remove the orange peel, yes you do remove dirt and other imperfectons during the same process, sometimes you are able to remove dirt w/o wet sanding and by just using a wool pad on a buffer.
Old 12-16-2007, 07:38 PM   #9 (permalink)
xzero's Avatar
Trader Rating: (15)
Yeah and everything really just varies depending who you take it to like some people will never go above 2000 grit but me and my shop we finish it up with 4k grit and then some good old fine buffing but quality paint jobs are definitely not cheap so just do some research before you take it to someone see some prior paint jobs and talk to prior customers.
Old 12-16-2007, 10:01 PM   #10 (permalink)
SINISTER_SRT's Avatar
Member Number: 56602
speak for yourself. have you ever seen my work? no.
SINISTER_SRT is offline   Reply With Quote
Old 12-17-2007, 08:42 AM   #11 (permalink)
How would they paint the front portion, its like thin plastic. Can you buy a new front area from the factory or something, just a thought because on most peoples cars the thin paint makes it look like a warzone after a while.
Old 12-17-2007, 02:42 PM   #12 (permalink)
xzero's Avatar
Trader Rating: (15)
They would sand it down and prime/seal it and paint like any other body part and yes you can buy a new front bumper.
Old 12-17-2007, 03:31 PM   #13 (permalink)
How much do those cost?
Old 12-17-2007, 05:25 PM   #14 (permalink)
cost is like mid 300 marked up to low 5's. But you really don't need a new bumper unless it's really damaged.
Old 12-17-2007, 05:33 PM   #15 (permalink)
Would it be cheaper to paint it? With a nice thick coat of paint that won't flake off like the factory thin layer.
Page generated in 0.20133 seconds with 11 queries
