Old 04-09-2008, 03:51 AM   #1 (permalink)
BigBoostdSRT4's Avatar
Member Number: 61622
Default pressure washing engine bay
I had a question about pressure washing the engine bay. A friend of mine informed me not to use any kind of pressure on the engine bay to just get a wet rag and whipe it down. The main questions is whether or not this is true as to the safety of pressure washing the engine..
BigBoostdSRT4 is offline   Reply With Quote
Old 04-09-2008, 06:14 AM   #2 (permalink)
stxsrt's Avatar
Member Number: 37057
Trader Rating: (28)
This is simple
1. Simple green automotive cleaner wait 10 minutes
2. Garden hose it down/ You dont need a superhigh pressure washer.
I wash the motor down while the car is running.
stxsrt is offline   Reply With Quote
Old 04-09-2008, 03:57 PM   #3 (permalink)
slickwillie's Avatar
Member Number: 47326
I just did mine [spray down with simple green wait 10 min then spay off with garden hose dont use alot of pressure] I did my with the engine cold
slickwillie is offline   Reply With Quote
Old 04-09-2008, 04:28 PM   #4 (permalink)
Member Number: 62954
You can use a pressure washer if you want to, just be careful not to spray directly over electrical connections.
If you don't feel comfortable using high pressure, just use a garden house.
Do it while the engine is running, and if you have access to an air hose, and blow dry it when your done.
nighthawk311 is offline   Reply With Quote
Old 04-09-2008, 08:51 PM   #5 (permalink)
WaLkInGaLoNe's Avatar
Member Number: 27922
Get your engine to tempreture, spray down with simple green, or a degreaser I prefer a debgreaser, let sit for a min or two, and just hose down, let the steam do is work and just make sure the engine is running, let the water evap from the engine back. Did mine last weekend all clean, no issues. Except for the damn squeeky tensinor.
WaLkInGaLoNe is offline   Reply With Quote
Old 04-10-2008, 12:21 AM   #6 (permalink)
haha my tensioner is squeeky too but we've also had quite a bit of rain...and that is one thing i will have to do next time...last time i went ahead and put degreaser on with the engine cold and then used light pressure on washing it off...
Old 04-10-2008, 02:50 AM   #7 (permalink)
srt4me18's Avatar
Member Number: 50825
I wonder how prone the exhaust mani is to cracking if it gets kind of wet????
hp61
AEM Ems, STock Head, Stock Cams, STock block
Aaronneon Tune=badass
60' 1.75
1/8 7.52@101.55
1/4 11.45@125mph
1.66 60' wasted on a 13.2@64mph
srt4me18 is offline   Reply With Quote
Old 04-10-2008, 03:58 AM   #8 (permalink)
Polygon's Avatar
Member Number: 40130
Personally, I wouldn't be spaying cold water on a hot engine.
I've always used a good degreaser like Gunk, Simple Green, or Greased Lightning and coat the engine bay. Cover up your filter if you have an open ended filter. Let it soak and then after a few min I get some car wash and give everything a good rub down and then hose off. No need for high pressure.
Clint:
1989 Chrysler LeBaron GTC Turbo II (Full On Project)
1991 Dodge Stealth R/T TT (Restoration)
Polygon is offline   Reply With Quote
Old 04-10-2008, 12:37 PM   #9 (permalink)
well i have a heated pressure washer and it has adjustable pressure on it i just used a degreaser and then sprayed lightly with the pressure washer no more pressure than a garden hose..but for the filter i didn't spray around it...i just kind of passed it...i just wanted to make sure that watering down the engine wouldn't cause lockup or anything...i mean i didnt' sandblast pressure it i just degreased then lightly washed off the residue..but i didn't know if there was any wires i needed to look out for or stuff like that next time i won't have too though.i'm gonna be getting a powdercoated valve cover shortly so i'll be just whiping off next time
Old 06-06-2008, 05:22 PM   #10 (permalink)
Member Number: 9221
Trader Rating: (18)
do you have to cover any wires up?
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is online now   Reply With Quote
Page generated in 0.18036 seconds with 11 queries
