Old 10-14-2009, 09:52 PM   #1 (permalink)
phs17's Avatar
Member Number: 67384
Default Flat Black (primer) problem
well i wanted my hood and trunk the flat black look so i just went to pepboys and bought black primer. so i sanded it down good, and started to prime and i was done priming you can see where i stoped then started painting again. theres lines . how do i fix this.
phs17 is online now   Reply With Quote
Old 10-14-2009, 10:00 PM   #2 (permalink)
AngrySrt's Avatar
Member Number: 71255
Trader Rating: (20)
more paint? lol
2003 srt-4 stage 1 pcm, DSP tuned by john at ptp, stage 2 injectors, agp wastegate with ptp spring mod,agp full race bfmic, agp intake, areoforce scan guage, mpx extrude honed mani,mpx 62 mm throttle body, cti charge pipe,agp up pipe with hks bov, aem wideband, 3 inch side exit, hold 17.
Jon at PTP is the shiznit!!!!!
AngrySrt is offline   Reply With Quote
Old 10-14-2009, 10:07 PM   #3 (permalink)
BrandynSRT's Avatar
Member Number: 63412
Trader Rating: (25)
you cant get an even paint job buy using a can on such a big surface. it dries to fast you will get lines....
BrandynSRT is offline   Reply With Quote
Old 10-14-2009, 10:37 PM   #4 (permalink)
phs17's Avatar
so theres no way this will work. and thanks for the lights there freakin sweet
Old 10-14-2009, 10:39 PM   #5 (permalink)
BrandynSRT's Avatar
Trader Rating: (25)
no problem.. it can be done i bought my truck and the guy spay painted the whole thing. cam out good.. but it is hard
Old 10-14-2009, 10:41 PM   #6 (permalink)
phs17's Avatar
do u kno what he did ? lol
Old 10-14-2009, 10:45 PM   #7 (permalink)
BrandynSRT's Avatar
Trader Rating: (25)
dont have a clue..sorry
Old 10-15-2009, 03:36 PM   #8 (permalink)
MikeBard's Avatar
Member Number: 64548
Try wet sanding the primer with fine sandpaper and then giving it another coat
WTB: Slicks or DR's for stock turbo car
MikeBard is offline   Reply With Quote
Old 10-15-2009, 11:22 PM   #9 (permalink)
Member Number: 73368
or just buy a cheap ass gun and shoot it. It will be sooo much better.
05 Flame Red NSRT-4
Black Rims (stock), HID's, 3" SEE, K&N CAI, AGP WGA, MSD Coil and Wires, Sportlines, Catch Can, AEM Uego Wideband, Mopar STS
coltf1991 is online now   Reply With Quote
Old 10-15-2009, 11:38 PM   #10 (permalink)
o5RedSrt-4's Avatar
Member Number: 71354
your spraying way to close. do a few even coats from far away then a really really really really light wet sand to take away the texture. i just did my hood not to long ago and was a whole trial and error process
o5RedSrt-4 is offline   Reply With Quote
Old 10-16-2009, 11:32 AM   #11 (permalink)
phs17's Avatar
did u use spraypaint. and was it primer?
Old 10-16-2009, 10:54 PM   #12 (permalink)
BrandynSRT's Avatar
Trader Rating: (25)
buy a sandable primer spray it then sand it with 800 grit till smooth.. then spray it with a flat black paint
Old 10-17-2009, 03:16 PM   #13 (permalink)
apexcrazy's Avatar
Member Number: 24279
Multiple light coats better than 1 or 2 heavy .
IMO , dont use a primer as your final coat . I actually think FLAT black looks like crap after a couple weeks/months . Try going with a satin final coat instead . it will withstand stains , prints , water , weather , & age , MUCH better then a porous flat surface . That , and it looks like you didnt just primer the damn thing .
Post up pics when finished !!!!!
_____ _____
apexcrazy is online now   Reply With Quote
Old 10-18-2009, 05:13 AM   #14 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
why not try flat black vinal coat, IMO flat black is next to impossible to pull off even by the best
Old 10-18-2009, 02:55 PM   #15 (permalink)
HiSpeed48's Avatar
Member Number: 48610
wet sand it, 1000-1500-2000 grit
should do the trick
Yamaha R6
"Ride Hard or Ride Home"
HiSpeed48 is offline   Reply With Quote
Page generated in 0.17123 seconds with 13 queries
