Old 09-06-2009, 08:41 PM   #1 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
Default Detail Carbon Fiber
Got a hood and trunk from a local that have some minor swirl marks on it..how can i remove them?3m rubbing coumpound,followed by a coat of mothers swirl remover and than some wax?
BIG TURBO!
Old 09-07-2009, 04:39 PM   #2 (permalink)
HiSpeed48's Avatar
Member Number: 48610
what are you using, an orbital polisher or a rotary?
try the least aggressive polish first and if that doesn't do anything use something stronger. so give the mother's stuff a try first on a small test area.
Yamaha R6
"Ride Hard or Ride Home"
HiSpeed48 is offline   Reply With Quote
Old 09-07-2009, 09:23 PM   #3 (permalink)
lancer117's Avatar
Member Number: 59029
clear coat it will be ur best bet .
Buckle up... it makes it harder for the aliens to suck you out of your car
lancer117 is offline   Reply With Quote
Old 09-15-2009, 12:12 PM   #4 (permalink)
Member Number: 50639
if your using a orbital buffer and the swirls are minor just use some polish with a orange pad and then some wax. if they are deeper you can use a compound as the first step and the second use a polish or a glaze then finish with wax.
vinnie22 is offline   Reply With Quote
Old 09-23-2009, 02:43 AM   #5 (permalink)
Member Number: 70979
at the end use a lot of wax to give the best shine to the parts
junior_x is offline   Reply With Quote
Page generated in 0.13395 seconds with 13 queries
