Old 11-22-2005, 07:59 PM   #46 (permalink)
17psi_srt4's Avatar
Member Number: 27216
try pissing on your car. i know it sounds far fetched, but sometimes i clean my car strictly with piss. just make sure that you rinse really well, or all the loose dogs in town will look at your car like a moving fire hydrant
2004 red srt-4, hand full o'bolt-ons, stage 0 4ever bytches
17psi_srt4 is offline   Reply With Quote
Old 01-31-2006, 04:27 PM   #47 (permalink)
JonnyBlaze's Avatar
Member Number: 37767
take it from from a detailer in a body shop, cheapest easiest way--glass cleaner with ammonia in it. the ammonia eats the wax right off. all the other stuff, wd-40, peanut butter(???) ect make your car dirty again, wd-40 puts silicone on your car and can possibly damage your finish
JonnyBlaze is offline   Reply With Quote
Old 03-11-2006, 03:54 PM   #48 (permalink)
fozjared's Avatar
Member Number: 34419
the back to black works just fine for me!
05 srt-4
fozjared is offline   Reply With Quote
Old 04-06-2006, 07:39 AM   #49 (permalink)
Member Number: 33848
Those white residue problems are a thing of the past, if you have that problem rest assure you are using the wrong brand of wax.
Turbo Wax is offline   Reply With Quote
Old 04-06-2006, 07:54 AM   #50 (permalink)
kenskiv's Avatar
Member Number: 2910
Please elaborate...
kenskiv is offline   Reply With Quote
Old 04-06-2006, 08:44 AM   #51 (permalink)
Some products have certain quality's in it that completely eliminate that problem, in fact you can go over and over on the trim and all you have to do is wipe it off, in addition.
Like anything else in the market place, all products seek their own level of justification based on the cost of producing the product and the quality of the ingredients in the product. some products were never intended to compete with the $3.99 products in the market simply because there is no comparison between the products, either in performance or quality of manufacture, however not all high end products are able to go over trim and leave zero residue.
A common characteristic of the lesser cost products in the market is the unusually high content of solvents in the product. High content solvent products will give a quick shine, that is true, but this will not last and through prolonged use of products like these will cause the paint to deteriorate and become dull on the surface.
Then after a while you will hear, that surface is so dull, I guess it needs to be buffed out. So, let's start out correctly by applying a coating to the surface that does what it is supposed to do and that is to protect the surface and give a long lasting shine.
Now if you have a product that performs very well, don't leave any white residue and protects you car finish,
Why will you want to use a product that you need to use another product to help the first product ?
It makes no sense, but since there's so many low quality products out there, some company's have found the need to make a product to address the problems of other products, prime example, white residue on trim.
Hope that helps
Old 05-27-2006, 03:24 PM   #52 (permalink)
05turbojellybean's Avatar
Member Number: 42218
any type of tar/wax remover should do it, careful with it though it can dull the rubber if you get too happy with it, if that does happen (or if you just wanna use it to make the rubber look better) meguiars vinyl/leather cleaner and conditioner 40 is awesome, wont leave black marks in your door jambs
05turbojellybean is offline   Reply With Quote
Old 10-10-2006, 11:56 AM   #53 (permalink)
Member Number: 31907
i got the fix lol a BIG BLACK SHARPIE PERMANENT MARKER LOL WORKS WONDERS!!!
i might try that wal mart stuff...
*2005 SRT-4
MODS:
Mopar 3 inch cold air intake
Fade's '05 TIP Mod
apexi neo fuel controller(tuned by topspeed of atlanta thanks)
msd 8.5 plug wires
slow boy racing wga (16 psi)
Greddy catch can
Greddy turbo timer
Custom 3' side exit exhuast
Prosport boost gauge
8000k quick whips hid kit
numbers as of 5/16/07
265hp and 273trq
SRT4Badboi is offline   Reply With Quote
Old 11-06-2006, 05:13 PM   #54 (permalink)
Member Number: 38229
windex
Currently:
Mopar STS(booger bushings)
Agp mm
S1
S2 wga
Eibach Pro Springs
3" with electronic cutout
Future:
Koni's
Enkei's
Perrin FMIC
Tsbrown is offline   Reply With Quote
Old 11-26-2006, 07:50 PM   #55 (permalink)
svtsrt's Avatar
Member Number: 41942
i'm gonna have to go with the pencil eraser too. it does get eaten up pretty quick but it's cheap and it works.
05 SRT-4
-Mopar stg3, Mopar BOV, sts, exhaust, CTI hotside pipe, JBM cc, Maxxfab dp w/ cat, AEM uego wideband, Aeroforce gauge-
svtsrt is offline   Reply With Quote
Old 01-14-2007, 11:01 PM   #56 (permalink)
SrTlove's Avatar
Member Number: 49668
I found using dish detergent then after a good rince. to use some back to black. works like a charm.
Cars, Love em all!
SrTlove is offline   Reply With Quote
Old 09-01-2007, 12:03 AM   #57 (permalink)
Ramsst's Avatar
Member Number: 47077
i know, i know, thread reserection FTW! but for the love of god people, stop spraying shitty cleaners, oils, and chemicals on your molding and mirrors....use a hard plastic bristol brush. the same texture as a hard tooth-brush but get a big one (chances are you probly have about 2 in your house for no reason) start rubbing and the dryed wax flakes off. after that, just wash the part off with soap and water.
did this to many cars, work amazing, fast , and free....one srt had the wax on the mirror for over a year and it fell right off....
or you can heat up peanut butter and spread it on while spraying a mixture of WD-40, back to black, armor-all, quick detailer, 303 areospace, windex, bug/tar remover, and palmolive dish soap, wipe that off and cover it all up with a big black permenant marker dipped in piss
Ramsst is offline   Reply With Quote
Old 09-20-2007, 08:08 PM   #58 (permalink)
TwitchSRT's Avatar
Member Number: 55677
toothbrush and degreaser.
TwitchSRT is offline   Reply With Quote
Old 10-02-2007, 06:25 PM   #59 (permalink)
SRT-4 FIRE's Avatar
Member Number: 786
Meguir's back to black is awesome but can stain your paint so be very careful and clean up any you get on the paint . I would not use dish soap or Simple Green on the trim . If it get's on the paint it will remove the wax you just put on . I use Meguir's natural shine rubber and vinyl protectant . I just wipe away the left over that get's on the paint with a clean terry cloth towel . Or the other stuff I use is Sprayway Instant shine . It's professional stuff that pro's can get from Pro auto care . It works awesome and last's for about 2 to 3 weeks even with a good washing . For the absolute best result when waxing your car use masking tape one the trim and any where else you don't want the wax to get to . Then you don't have to do any thing to get it off your car .....
BTW : If you get some extra wax in some tight spaces ( door jams, around the spoiler, Ect. ) use a 1" cheapy wood handle paint brush and cut the bristles off at about 1" at an angle and then wrap masking tape around the metal part of the brush to protect your paint from scratches . You can also use this brush to detail the interior of your car like the vent's and small cracks on the dash and door panels.
04 SRT-4 Flame Red Of Course ! AGP 3" CAI , Kenetic WGA , Motor Mount Inserts , Greddy TT , TWM STS , Blood Red VC , Hand Made oil catch can , Fan swich mod .
SRT-4 FIRE is offline   Reply With Quote
Old 03-07-2008, 06:20 PM   #60 (permalink)
03neonSE's Avatar
Member Number: 40371
Quote: Originally Posted by Tuners View Post
a little rubbing alcohol to get it off, and some typr off a dash cleaner. like a champ.
rubbing alcohol didnt work for me.
2003 Dodge Neon SE <> 65,xxx -- #223639 neon built
Quote: Originally Posted by Milkit18
srt4s ain't no typical neon.
03neonSE is offline   Reply With Quote
