Old 09-13-2008, 05:12 PM   #1 (permalink)
mopar dude's Avatar
Member Number: 34234
Default bugs ate clear coat
I have an 05 flame red srt-4 and a few days ago, I encountered some love bugs. Being a full time college student with a part time job, I don't have much time or energy at all to keep it as clean as i would like. The love bugs ate/etched the clear coat on my front bumper and on the hood a little. Is there ANYTHING that I could use to correct this? I know that nothing short of getting it repainted will take care of it completely but is there some kind of rubbing compound, wax, or clay bar that could help clean the clear coat up and make it look decent again? Links to products would be much appreciated. Thanks for your time.
mopar dude is offline   Reply With Quote
Old 09-15-2008, 07:06 PM   #2 (permalink)
mopar dude's Avatar
cmon, I know some of you detailing gurus have to know of something I can do that will help.
Old 09-25-2008, 08:40 AM   #3 (permalink)
sti_zee's Avatar
Member Number: 40201
anything you do to blend those blemishes will remove paint. post a pic.
sti_zee is offline   Reply With Quote
Old 10-01-2008, 03:33 PM   #4 (permalink)
sfla_srt4's Avatar
Member Number: 61295
Trader Rating: (13)
try bug and tar remover.. I got it at wallmart. It took off some tree sap on my front fender!
sfla_srt4 is offline   Reply With Quote
Old 10-23-2008, 10:36 PM   #5 (permalink)
lphooper03's Avatar
Member Number: 37050
There is nothing that you can do. I had the same issue on my old Red SRT-4 as well. The previous owner didn't take care of the paint and let the dead bugs sit on the car and eat away the clear. I tried EVERYTHING. You name it. Every name brand wax...tar remover...bug remover...household crap. Nothing wanted to make the blemishes go away. I even tried Zaino clay bar and wax kit and that made everything else look AMAZING, just didn't get rid of the clearcoat blemishes.
50 Trim + Diablosport =
Old 10-24-2008, 03:51 PM   #6 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (42)
x2.......best u can do is repaint it & if the body shop does a crappy job it will still be there
Crane 14's
Ragin_SRT is online now   Reply With Quote
Old 10-25-2008, 09:21 AM   #7 (permalink)
04BlueSkittle's Avatar
Member Number: 52567
Trader Rating: (34)
X2 i had mine clay barred and everything and still resides the spots. so now i am just gonna black out the cross bar and black my front lip the width of the crossbar.
Quote: Originally Posted by Goldenshisno View Post
Wouldn't a little water be OK because when you heat up water it turns to steam the Hydrogen separates from the O2) and so all you would be adding is some extra air and hydrogen and last i checked that's pretty flammable.
Quote: Originally Posted by S10jimmi View Post
What? Steam is still H2O. It doesn't separate into H and O2, thats much more complex. It stays as H2O.
04BlueSkittle is offline   Reply With Quote
Old 10-26-2008, 10:01 PM   #8 (permalink)
Member Number: 9051
Trader Rating: (17)
Yeah.. the best you can do is sand it with 2000 sandpaper... just to get the affected area off... but you risk going through the clearcoat...
pphilps is offline   Reply With Quote
Old 10-27-2008, 11:45 PM   #9 (permalink)
Sriquixotic's Avatar
Member Number: 13225
There is hope, I encounter this problem all the time. You just need some polish like meguiars swirl remover and keep working it in until it goes away, also dont press hard and clean the surface first. If it doesn't work after 3 tries or so then move up to a stronger polish like their fine cut cleaner. An orbital buffer will make life 10x easier. If you never used polish before I wouldn't recommend sanding paper because you can easily make things worse if it's not done right. Do not try rubbing compound first, start with a light polish which is the least abrasive then gradually go stronger if needed. There's also a vendor on this site called Adams that has good stuff from what I hear.
Sriquixotic is offline   Reply With Quote
Old 10-30-2008, 08:06 AM   #10 (permalink)
red2.4srt's Avatar
Member Number: 43649
Trader Rating: (12)
LOL. Pushing hard is the idea behind POLISHING. Meguiars Scratch-X is the least abrasive hand polish made, it's also a diminishing abrasive. That means as you work it, the abrasiveness wears down and becomes more of a moisturizing agent for the clearcoat, since paint is porous like skin. Don't be afraid to push hard as shit with a foam pad, multiple applications may be necessary. If it doesn't do much after 3 tries, move up to the next step abrasive. Hopefully that helps him out! Best of luck!
red2.4srt is offline   Reply With Quote
Old 11-01-2008, 05:20 PM   #11 (permalink)
harold97's Avatar
Member Number: 63330
Be VERY careful sanding and compounding the front of an SRT-4! The paint is not always as thick on the fenders and hood as it is on the rest of the car!
Even if you have years of experience, you should still be careful, but it is probably not the place to learn wet sanding and corrective compounding unless you have given up and are planning to repaint he front end anyway.
Last edited by harold97 : 11-01-2008 at 05:21 PM. Reason: I missed an important word!
harold97 is offline   Reply With Quote
Old 11-01-2008, 06:44 PM   #12 (permalink)
smokin_clays's Avatar
Member Number: 56121
same thing on my 05 OB. 1st owner didn't do shit to keep the front clean. my whole lip is owned, and a few spots on the front bumper closer to the hood. when i claybar or wax or anything i just avoid the front bumper because it seems to make it worse
smokin_clays is offline   Reply With Quote
Old 11-01-2008, 06:54 PM   #13 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
I live in Oregon and have heard about the love bugs in Florida. Heard you have to make the time to get them off immediately or they will kill your paint. Bummer.
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is offline   Reply With Quote
Old 11-03-2008, 07:43 AM   #14 (permalink)
LOL that is not the idea behind polishing. If he's polishing by hand he shouldn't press hard, that'll do nothing for the paint except induce other marks and you can't "push hard as shit with a foam pad" cause the machine will bog down, well that is if you're referring to a foam pad on a machine. Scratch-X is a joke because it contains fillers that will cover up the blemish temporarily.
Old 11-03-2008, 05:04 PM   #15 (permalink)
red2.4srt's Avatar
Trader Rating: (12)
I dunno about you, but I apply Scratch-X by hand, with a small foam pad. Induce other marks? Isn't the idea of polishing, inducing miniscule marks all over to bring the clearcoat down to the level of the scratch you're removing? I agree, Scratch-X is a joke for everything but a small scratch put on the car by the wind blowing...
Page generated in 0.21755 seconds with 13 queries
