Old 02-19-2008, 01:20 PM   #1 (permalink)
Member Number: 41538
Default Black sut in the exhuast
guys what product can i buy to clean the inside of my exhuast? I look inside of there and see noting but black sut,grit, and grime stuck on the inside of my catless exhuast: ( and im sure it goes all the way up
fastman is offline   Reply With Quote
Old 02-19-2008, 01:26 PM   #2 (permalink)
STUDLEE1A's Avatar
Member Number: 54852
you can use throttle body cleaner (carb cleaner) to clean it and a wideband and map clamp to keep it clean
S1, NeedsWings DP, MPx BFMIC, AEM UEGO, AGP UPP w/HKS, WGA (17/14), 55MM TB, Oil Modifier, Maddog 80% w/ Pizza Boy Ball, Soild AGP Tranny Mount/ MM Race Inserts, MSD CP/Wires, Iridium Plugs (Stock Heat Range), 180*, Viper 791XV with Remote Start/Turbo Timer, 6K HIDs, Hood Struts.
STUDLEE1A is offline   Reply With Quote
Old 02-19-2008, 02:05 PM   #3 (permalink)
connsrt's Avatar
Member Number: 48865
Trader Rating: (129)
fine steel wool and all purpose cleaner
SHE WILL BE MISSED
connsrt is offline   Reply With Quote
Old 02-19-2008, 10:40 PM   #4 (permalink)
Member Number: 60626
Hey fastman,
Try using some sort of a degreaser on the effected areas!!! And also a really crappy towel. Adam's makes an All Purpose Cleaner that would work great!
Let me know if you have anymore questions, posts before and after Pics if you can with your process!!
Thanks,
Justin@Adams is offline   Reply With Quote
Old 02-20-2008, 04:47 PM   #5 (permalink)
Quote: Originally Posted by Justin@Adams View Post
Hey fastman,
Thanks,
its on the inside of the tail pipes
Old 02-21-2008, 10:09 AM   #6 (permalink)
Hey fastman,
Do you just want to clean the area that you can see, or are you looking to clean out the entire system?
Let me know!!!
Thanks,
Old 03-30-2008, 06:12 PM   #7 (permalink)
Hey fastman,
Let me know!!!
Thanks,
i want to clean out the system BUMP
Old 04-02-2008, 01:06 PM   #8 (permalink)
Member Number: 49579
sut?
sut????
srtprince is offline   Reply With Quote
Old 04-03-2008, 06:11 PM   #9 (permalink)
Member Number: 59717
Fastman,
As Justin and a few others have mentioned, try cleaning a majority of the junk out with a good All-Purpose Cleaner and some old towels. Once you have removed the heavy dirt, you can simply use some metal polish on the inside of the tip. If your tip is stainless steel, chrome, or even aluminumized, polishing it will help to remove any excess tarnish and it bring it back to life.
I do this process on my Dad's diesel pick-up every once in a while and it makes that soot filled tip look like NEW.
Good luck and please let us know if you have any additional questions!
-Dale
Dale@Adams is offline   Reply With Quote
Old 04-07-2008, 01:25 PM   #10 (permalink)
Ramsst's Avatar
Member Number: 47077
what?! its going to be black inside the exhaust man...just polish the tip/tips and your set! also...if you are concerned about the carbon buildup, look into SeaFoam...does wonders. just dont use it when the nieghbors are home
Ramsst is offline   Reply With Quote
Old 04-09-2008, 09:27 AM   #11 (permalink)
KBizzle's Avatar
Member Number: 30144
this is why when I get off my lazy ass I am painting my tips black...
KBizzle is offline   Reply With Quote
Old 04-15-2008, 07:39 PM   #12 (permalink)
my_little_srt's Avatar
Member Number: 41179
I would say that all mufflers are black on the inside of the tips....I mean you could clean it, but why....
my_little_srt is offline   Reply With Quote
Page generated in 0.23851 seconds with 11 queries
