what is the best sway bar? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-16-2012, 05:34 PM   #1 (permalink)
spitefire1's Avatar
Member Number: 90771
Default what is the best sway bar?
Looking to purchase a set of sway bars front and rear for my srt . Just wanna know what u guys things is the best. Lmk thanks guys
spitefire1 is offline   Reply With Quote
Old 11-16-2012, 05:38 PM   #2 (permalink)
Ridin59vette's Avatar
Member Number: 86347
I have the hotchkis sway bars. Only thing shitty about them is the $70 replacement end links.
Then again if i wasn't in a rush i probably could've gotten them off without waffling them
SCH-I510 using AutoGuide.C
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is offline   Reply With Quote
Old 11-16-2012, 05:51 PM   #3 (permalink)
spitefire1's Avatar
How much r they. And how big are they and how do they compare to like Mopar and eibach ?
Mod list
Dcr block
Agp 50 trim
Dsp
Aem meth
Rc 750cc
Agp Fmic
DCR lca
Bc coilovers
Wilwood front brakes
Perrin sts
Custom side exit
Agp return line
Walbro
Enkei rpf1s. Sexy
Old 11-16-2012, 06:00 PM   #4 (permalink)
Member Number: 35677
Default Stock bars are generally adequate
Before you stick aftermarket bars on your car, for 1/5 the money, try at least ONE set of polyurethane bushings on your OEM bars. Then decide.
Except for the hardest driving, the OEM bars, when refitted with polyurethane bushings are really pretty robust and do a good job.
ValleyRacer is offline   Reply With Quote
Old 11-16-2012, 06:08 PM   #5 (permalink)
spitefire1's Avatar
Ya I'm going to try that first. For sure. The old white ones r worn out .
Mod list
Dcr block
Agp 50 trim
Dsp
Aem meth
Rc 750cc
Agp Fmic
DCR lca
Bc coilovers
Perrin sts
Custom side exit
Agp return line
Walbro
Enkei rpf1s. Sexy
Old 11-17-2012, 01:10 PM   #6 (permalink)
SRTforums Admin
stowaway's Avatar
Member Number: 3286
Hotchkis is the most highly regarded, and read the suspension FAQ thread.
Old 11-17-2012, 02:52 PM   #7 (permalink)
Default bushing deflection
Keep in mind, that no matter how fat (diameter) your torsion bar, or how stiff the metal alloy, shaping, hollow, solid, adjustable positions et.al. - until the bushing material quits moving or in particular quits SQUISHING, the bar dunt do any work.
The bar resists twisting when the car body "leans"(short version). So the soft bushings deform first and you have about 1 inch SLOP (left and right side = 2 inches), by then the other suspension components & tires are already overloaded.
I wouldn't fault you for getting larger bars, but before you pony up $$$ try upgrading the rear OEM bar first. One or two sockets is all that's required and $50.
Then decide. Keep us posted and put up some pix............
Old 11-17-2012, 03:48 PM   #8 (permalink)
mole''s Avatar
Member Number: 17477
Out of the ones I have tried.
#1 Hotchkis
#2 Mopar
#3 eibach
#4 progress
#5 Mopar welfare sways
DCR spiced and Tuned by the Mad Scientist team
Jay@N2MB and Nigel@BST (turbo666)
Mole' (STOCK TURBO) 16g BWS setup #s
380hp+ and 444tq+
11.7@122
1.71 60ft
PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com .
Old 11-17-2012, 05:02 PM   #9 (permalink)
Default what bushings?
#1 Hotchkis
#2 Mopar
#3 eibach
#4 progress
Mole you devil - what bushing set up did you have? Any pictures to share?
I have a sway bar upgrade lurking on my "radar".................
Old 11-17-2012, 05:09 PM   #10 (permalink)
mole''s Avatar
ES or supplied bushings with the bars.
Get Hotchkis. I have a spare set of used Mopar sways in my garage.
380hp+ and 444tq+
11.7@122
1.71 60ft
Old 11-17-2012, 07:04 PM   #11 (permalink)
SRTforums Admin
stowaway's Avatar
Member Number: 3286
#1 Hotchkis
#2 Mopar
#3 eibach
#4 progress
Once again I'll say it, eibach sucks and the part is designed for a regular neon. The front is the same size as stock so outside of being a different color it is a waste.
Old 11-17-2012, 07:09 PM   #12 (permalink)
Global Moderator
friend088's Avatar
Member Number: 52654
I need to buy a set in Jan or Feb. Thanks for the advice!
Join us for the world's largest SRT-4 PARTY!
2013 5th Annual SRT-4 Showdown 10.20.13
Expected attendance: 150 SRT-4s
https://sites.google.com/site/2013srt4showdown/
friend088 is offline   Reply With Quote
Old 11-17-2012, 07:35 PM   #13 (permalink)
Stowaway, Is there an alternative to getting the endlinks for the rear sway bar other then directly from hotchkiss that you know of? I've searched around but all I could find was a replacement directly from them
FS Thread:
Old 11-17-2012, 08:41 PM   #14 (permalink)
mole''s Avatar
Did not know that.
Thanks for the knowledges
Would like to know this too.
380hp+ and 444tq+
11.7@122
1.71 60ft
Old 11-17-2012, 09:56 PM   #15 (permalink)
SRTforums Admin
stowaway's Avatar
Member Number: 3286
Make your own with a normal end link or threaded rod and a small rod end.
