Old 10-10-2009, 04:29 PM   #1 (permalink)
TuRbO_KiD88's Avatar
Member Number: 40916
Trader Rating: (18)
Default Vibrations from 15-25 mph
Yesturday I had a TOB Fork, Axles, and wheel bearings installed on my car cause all of those pieces were really warn out. Everything went fined no issues. Expect that know from 15 to 25 mph theres a real mild shake thats coming from the steering wheel. Any ideas as to what it can be?
TuRbO_KiD88 is offline   Reply With Quote
Old 10-10-2009, 05:18 PM   #2 (permalink)
my_little_srt's Avatar
Member Number: 41179
Trader Rating: (24)
Somethings loose..........
my_little_srt is offline   Reply With Quote
Old 10-10-2009, 05:24 PM   #3 (permalink)
Trader Rating: (18)
took the wheels and shake everything and nothing even budges or makes a noise.
Old 10-11-2009, 09:36 AM   #4 (permalink)
Trader Rating: (18)
bump to solve my problem
Old 10-19-2009, 08:35 AM   #5 (permalink)
Member Number: 17238
check your tranny mount. what type of axles?
srtfreak69 is offline   Reply With Quote
Old 10-19-2009, 08:37 AM   #6 (permalink)
funny thing i changed my clutch and passenger axle and im getting the same thing........might be the axle????? i bought a Dorset from napa
Old 10-21-2009, 08:44 PM   #7 (permalink)
bump cause i have similar problem!
Old 10-21-2009, 11:06 PM   #8 (permalink)
Trader Rating: (18)
i was thinking it was a defected axle maybe. Just everything is bolted up tight.
Old 10-22-2009, 11:30 AM   #9 (permalink)
maybee, but is bothering the hell out of me! im going to check it out again today. let me know if you find a solution.
Old 11-16-2009, 01:33 AM   #10 (permalink)
Member Number: 71225
if they are reman axles then the axles are your problem!
AnsareStg0 is offline   Reply With Quote
Old 11-16-2009, 01:41 AM   #11 (permalink)
Drago's Avatar
Member Number: 65338
jack up the driver side enough for the tire to spin. go about 40mph it should be smooth, do the same for the passenger side. if it shkes then it is the axle....oher minor issues could be a loose sway bar or anything relating to the steering componets,
Drago is offline   Reply With Quote
Old 11-16-2009, 08:55 AM   #12 (permalink)
Trader Rating: (18)
yea turned out to be a bad driver side axle..I need to find some time to swap them out, been driving it with the vibration for a month now.
Old 11-16-2009, 05:47 PM   #13 (permalink)
talk talk88's Avatar
Member Number: 75856
I got a wobbling in front in my car when ever i accelerate, so can i jack up one side of the car and go up to 40mph to see which side shakes?
talk talk88 is offline   Reply With Quote
Old 11-16-2009, 08:10 PM   #14 (permalink)
no!
Old 11-16-2009, 09:20 PM   #15 (permalink)
Trader Rating: (18)
I pm'd you!
Page generated in 0.14718 seconds with 13 queries
