Old 10-23-2009, 07:35 PM   #1 (permalink)
rx7bandit's Avatar
Member Number: 75715
Default sway bar end links
a few days after buying my srt 4 i found the links that connect the sway bar to both sides of the front suspension were not there. The car was lowered before i got it. would this be because the after lowering it they stock ones wouldnt fit or is this just something the previous owner didnt see as necessary? Will i need aftermarket pieces to properly hook the sway bar up or will stock ones work?
rx7bandit is offline   Reply With Quote
Old 10-23-2009, 08:37 PM   #2 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
old ones prolly broke off or worn out,and he took them off and never put new ones on
BIG TURBO!
Old 10-24-2009, 07:09 AM   #3 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
There should be zero clearance problems when you lower the car. Just get an OE or the correct part from an Energy Suspension dealer and you'll be fine. You'll notice a huge increase in handling performance and steering response when you get it back together.
Old 10-25-2009, 09:55 AM   #4 (permalink)
Member Number: 70589
Talking
Sounds like my lowered nightmare-check the front bushings,tophat bearing,struts too-mine were blown.
Sunofwolf is offline   Reply With Quote
Page generated in 0.11829 seconds with 13 queries
