you aren't going to get a good ride witih that kind of drop if you keep the stock struts. They aren't designed for stiffer springs OR reduced ride height. They will bottom out easily, blow, and make you have even worse ride and handling. Now you have to pull them, buy coilovers, koni inserts, or tokico illumina struts and do another install and alignment. Do it right the first time and get Mopar, KW, or BC coilovers if you want to lower more than what the Mopar springs will do.
