Old 07-08-2008, 08:14 PM   #1 (permalink)
Member Number: 50897
Trader Rating: (12)
Default Ride is bouncy after spring install...
I recently installed some goldline springs on my stock 04 struts. The drop is pretty much exactly how I wanted it which is great. The only problem is the ride is unbearably bouncy. Is there anyways to fix the bounce from aftermarket springs? Does anyone else have this issue?
04 Black(kinda) SRT-4
Installed: FM WGA, Modified ED dual Exhaust (black), BDJ's 3" CAI ceramic, Bwoody Checkvalve, X02 BFMIC, Cold Side Pipe with Raptor BOV, Techgauge, Upper DogBone, Oil Modifier, 18" HPD Bronze wheels, and Goldlines
Waiting go be Installed: PTP FTM, Wideband, Lower MM insert
xbladr is offline   Reply With Quote
Old 07-08-2008, 08:50 PM   #2 (permalink)
BlackOhFour's Avatar
Member Number: 26183
Stock shocks dont usually last long on lowered springs.
Did you cut your bump stops int he front? I cut mine to get a little more travel.
The ride was terrible on those springs with stock shocks so I went coilovers.
Pittsburgh Crew - Join up: http://www.pittspeed.com
Quote: Originally Posted by RedLineGSR94
you managed to get 8 DSMs together in one place??? did you own a junkyard???
BlackOhFour is offline   Reply With Quote
Old 07-08-2008, 09:19 PM   #3 (permalink)
SoCalHybrid's Avatar
Member Number: 52814
^^^ Yep. Most people don't realize, but the shock and the spring are partners in controlling suspension. The spring (seriously) absorbs the shock [aka sharp motion, not the mechanical "shock" also known as a damper]. The shock [device] is used to dampen the spring. If the spring rate is too high relative to the shock/damper, then you get this decaying sinusoidal motion that slowly converges to the spring's natural height. On the same hand, if the damper/shock is valved to stiff for the spring, you will get a harsh ride that does not use the full travel of the spring.
When shocks go bad, they usually leak or blow out, in which case a substantial part of the device (pressurized gas or semi-vicous oil) leaks out, therefore substantially changing the valving. Essentially, the shock becomes weaker, and that's why the old-fashioned way to test is to bounce the corners of the car and see how many cycles it takes before the corner settles down.
I had eibach pro-kits with (what I think were) blown struts. The bouncing was horrible, and it bottomed out all the time because of the virtually nonexistent damping. On a different vehicle, a 2003 350z, I had completely stock suspension. I little known fact about the 350z is that Nissan messed up the valving of the shocks and had a quiet little mid-year fix in 2004. Ironically I found myself replacing the stock suspension with tokico d-spec adjustable racing shocks in order to get a smoother ride...Basically, Nissan under-damped the stock springs.
The SRT-4 is a little more difficult from what I've read. There are very few options, and the ACR package will not fit stock wheels/tires. Like the above person said, coilovers are pretty much the only way to deal with the srt-4 geometry. FWIW, I actually ended up selling my pro-kits, and went with a stock setup. (I've got herniated discs L5 & L6 so I can't handle a rough ride)
RUgoinUp 2 Heaven? Ever lie, steal (big or small), commit adultery (in deed or thought), use God's name in vain? Those are just 4 of the 10 Commandments, breaking just 1 condemns you to Hell. Claiming to be a "good person" won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit your guilt, and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
SoCalHybrid is offline   Reply With Quote
Old 07-09-2008, 02:05 AM   #4 (permalink)
my_little_srt's Avatar
Member Number: 41179
This is why I opted for H&R springs. No bounce............
my_little_srt is online now   Reply With Quote
Old 07-09-2008, 02:21 AM   #5 (permalink)
kup@l's Avatar
Member Number: 53972
I have eibach sportlines, gud look and stance. However, bad ride; I eventually got used to it of course. SO far 2 and a half years of survival. Getting bouncier every now and then. Hopefully I can find a good set of coils.
kup@l is offline   Reply With Quote
Old 07-09-2008, 02:25 AM   #6 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (49)
Pretty much all springs are going to ride like cunt. I have had 3 diffrent springs (Sportline, Pro Kit, and Progress) Finally said fugg it, and went with coil overs....Should have done that from the getgo.
ASE Certified Automotive Technician
Old 07-09-2008, 02:46 AM   #7 (permalink)
kup@l's Avatar
Lol DAMN, couldn;t get it straight huh hah
Old 07-09-2008, 10:01 AM   #8 (permalink)
Trader Rating: (12)
alright sounds good to me i guess i will man up and deal with it. I figured since the spring rates on the goldlines are almost identical and I mean the fronts are the same as stock and rears about 10 harder they wouldnt be as bad. I guess I will deal with it till coilovers.
Old 07-09-2008, 10:13 AM   #9 (permalink)
JdM2UsDm's Avatar
Member Number: 47984
Trader Rating: (18)
x2 on that i had h&r and no complaints what so ever none of that bouncy shit .. they sit like maybe a 1/2" higher than the goldlines but ride alot better i would know cause i had both springs... Ima throw h&r's on my IS300 also
New project
2003 Lexus IS300 pearl white
5-speed manual W/ LSD
Boost coming soon!!!
2005 Stone White (traded )
266WHP 320TQ
Stock turbo 19psi spike 16psi redline S1, 650cc, afc neo, cai, 3" tbe, slipping clutch everything else stock.
JdM2UsDm is offline   Reply With Quote
Page generated in 0.29113 seconds with 11 queries
