Old 10-15-2009, 02:33 PM   #1 (permalink)
SRT-DARREN's Avatar
Member Number: 37094
Default Rear Wheels Bow Outward.. Please Help.
3 years ago I lowered my car with Eibach Pro Kit springs, but did not replace the stock struts. As assumed, my stock struts blew and I had to totally replace the stock suspension.
My question is that whenever I lowered it the first time, the rears wheels seemed to bow outward. I understood this to be attributed to the fact that I did not get a rear camber kit for the car. I thought that by raising it back up to stock it would fix the problem, but the rear wheels still seem to bow outward. Does anyone know why this is?
SRT-DARREN is offline   Reply With Quote
Old 10-15-2009, 05:57 PM   #2 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
pictures? The rear of the SRT-4 will have a decent bit of negative camber in the rear from the factory. If you are worried about it take it to an alignment shop and have them put it on the rack and get som readings. If you have more than -1° camber in the rear then it could need adjusting. The toe shouldn't be out of spec unless you've bent something but that's something they could easily check and correct while they have the car.
Page generated in 0.14613 seconds with 13 queries
