i bought ebay drilled/ slotted rotors from company called Eagle Brakes out of California, and bought good quality semi metallic brake pads from advance auto parts.
When I brake from the
rear right and left I hear what I can describe as putting a baseball card on bicycle spokes. Like a flapping air sound/ flickering.
After reading I found out that it matters how you install rotors depending on the veins inside the rotor. Turns out my mechanic did install the fronts correctly and I have no issue with the fronts anyways.
But my rears were not correct, I didn’t think it matted since the rears rotors don’t have veins. So today I swapped the rotors from left to right hoping it would make the noise when braking go away, and it did not. I still get the same noise after swapping the rotors around
My mechanic thinks it’s the pads. But I’m now reading and it seems like it may be common noise with drilled rotors but I can not accept that. You should not be having any noise when braking. If so then I may have to put regular rotors in the rear.
should i try different pads like my mech. says. and if that dont work tehn change the rotors? i thinking of doing that to get to the cause of the noise when braking.
Rear:
Front:
