Old 11-03-2009, 07:19 PM   #1 (permalink)
Big_Daddy's Avatar
Member Number: 35480
Default pt alignment help
hey guys i have to do an alignment on my dads pt. i needs camber adjustments front and rear. do i need two camber bolts per side for the front? and how do i determine what shim i need for the rear? thanks for the help.....
Big_Daddy is offline   Reply With Quote
Old 11-03-2009, 07:31 PM   #2 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Well how bad is it out front and rear? that'll tell you what degree shim(s) you'll need.
Old 11-03-2009, 07:33 PM   #3 (permalink)
Big_Daddy's Avatar
front and rear camber on the left side are in the red..i have the exact number would you be able to tell me what i need? i just put four tires on his car sat.
Old 11-03-2009, 07:38 PM   #4 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
How bad is it out? I've aligned a few thousand PT's and the rear has never been outta spec (in red) unless something is bent, hit something etc.
Old 11-03-2009, 08:00 PM   #5 (permalink)
Big_Daddy's Avatar
the front def needs the bolt/s. i am only concerned on the rear. the left rear is at -0 degrees 27 minutes. thats the camber and the toe is at +0 degrees 02 minutes. the alignment machine is one of the new ones that goes further than degrees. the right rear was in the green. the left front camber is -0 degrees 28 minutes and the right side is =0 degrees 03 minutes. the right front i want to pull out a little so i am gong to put camber bolts on both fronts. any suggestions for the rear?
Old 11-11-2009, 06:34 PM   #6 (permalink)
apexanimal's Avatar
Member Number: 41793
you'll need shims in the rear - it's easy to do but you have to take the hub off...
Scott - '03 GT 5spd: E1 + DSP
DO RESEARCH!!!
The PTGT Webpage!!
apexanimal is offline   Reply With Quote
Page generated in 0.13106 seconds with 13 queries
