prothane bushings - Dodge SRT Forum
post #1 of 27 (permalink) Old 11-04-2010, 09:08 AM Thread Starter
Quoted: 0 Post(s)
prothane bushings
i just bought and installed my rear prothane sway bar links and bushing
front prothane sway bar links and bushings and front lower control arm bushings and thought id mention how ver very pleased i was
if your looking for a great improvement in handling steering response and sharpness without spending a ton of money this is the way to go. took me about 2.5 hours to install and wow was i suprised at how much better the car feels. also helped some with wheel hop. just thought id give my opinion on my satisfaction
whitesr05 is offline
post #2 of 27 (permalink) Old 11-04-2010, 01:14 PM
moparmemo's Avatar
Quoted: 0 Post(s)
Do u have to press the lower control arm bushings to install them?
LET ME TELL YOU SOMETHING!!!!
moparmemo is offline
post #3 of 27 (permalink) Old 11-04-2010, 02:34 PM Thread Starter
Quoted: 0 Post(s)
nope they slide right in but you do have to use the original outer and inner sleeves of the rearward bushing on the front control arm. the outer sleeve stayed in when i pushed out the old bushing and i burned off the rubber that was on the inner sleeve. front bushing i pressed out but the new prothane one slid right in
post #4 of 27 (permalink) Old 11-04-2010, 02:37 PM
Quoted: 0 Post(s)
rear c-arm bushings
Over thanksgiving vacation, I"m going to work with a friend to finally get the rear c-arm bushings installed and I"ll post up pix
prothane good stuff!
ValleyRacer is offline
post #5 of 27 (permalink) Old 11-04-2010, 06:08 PM Thread Starter
Quoted: 0 Post(s)
let me know how they are and if they made a difference i want to do them next
post #6 of 27 (permalink) Old 11-05-2010, 07:37 AM
BOOSTMONSTR's Avatar
Quoted: 3 Post(s)
Yup. Replacing rubber bushings with poly ones is one of the best things you can do for your car. More precise control, no more slop, and less wheel hop. I constantly replace bushings for all types of cars for average customers, with poly bushes, and my customers always call me back and tell me how it feels better than when they bought the car new!
Always get an alignment afterwards, because it changes the position of the control arms slightly.
Garrett t3/t4 60-1 with anti-surge full E85
255 w/ bnf feeding surge w/ Bosch 044
1200cc seimens / aero fpr / fuel cooler
Cti charge pipe/ hotside/ cx bfmic/
Ed cold pipe w/ greddy type s/ 55mm tb
4" intake/ stock longblock -bs chain
Bc br 6k/6k, prothane master kit
Progress front and rear sways/
18x8.5 Rays gramlights on fed 595ss.
BOOSTMONSTR is offline
post #7 of 27 (permalink) Old 11-05-2010, 03:07 PM
rosejm's Avatar
Quoted: 0 Post(s)
If you did the fronts yourself (and it sounds that way) the rear is really pretty easy.
As long as the bolt through the outer end/spindle isn't bent or rusted in place.
If it doesn't turn easily, I'd recommend sourcing a replacement BEFORE you've broken the old one. They weren't readily available when I needed one...
Oh, and mark/remember which way the lateral arms face and their position. The parts are not identical (2, 1, 1) and do not face the same way on each side of the car.
And get an alignment when you're finished
rosejm is offline
post #8 of 27 (permalink) Old 11-06-2010, 08:02 AM Thread Starter
Quoted: 0 Post(s)
yea i did them myself and aligned it too im actually a tech at a dodge dealership so parts and tools are pretty easy to get. good to know about the lateral arms tho i didnt know they were different.
post #9 of 27 (permalink) Old 11-06-2010, 05:09 PM
cokey's Avatar
Quoted: 5 Post(s)
Which dealership?
cokey is offline
post #10 of 27 (permalink) Old 11-07-2010, 09:46 AM Thread Starter
Quoted: 0 Post(s)
Originally Posted by cokey View Post
Which dealership?
Ruge's chrysler dodge jeep in Rhinebeck ny
post #11 of 27 (permalink) Old 11-09-2010, 12:06 PM
cokey's Avatar
Quoted: 5 Post(s)
Damn was hoping you were closer... like red hook lol.. that's a pretty long commute...
cokey is offline
post #12 of 27 (permalink) Old 11-10-2010, 11:50 AM
Quoted: 0 Post(s)
just got urethane bushings and coilovers, thinking about doing the bushings myself, how hard is the work and what kinda tools would you recommend besides the obvious?
IluvTh3srt4 is offline
post #13 of 27 (permalink) Old 11-10-2010, 12:19 PM Thread Starter
Quoted: 0 Post(s)
rhinebeck and red hook are right next to each other i actually live in red hook. red hook is still a about an hour n a half to 2 hours from the city.
post #14 of 27 (permalink) Old 11-10-2010, 12:27 PM Thread Starter
Quoted: 0 Post(s)
the sway bar links n bushings are easy n only require basic tools but for the LCA bushings you'll need a way to press out the old bushings or burn all the rubber till you can hammer them out but thats gonna smell pretty bad lol. you actually need to save the inner and outter sleeve of the old bushing. (only for the rear bushing of the front LCA) i used an air hammer but not sure if you have access to air tools. putting them back in though is the easy part.
you'll also need an alignment afterwards or atleast you should get one
did your bushing kit come with instructions?
post #15 of 27 (permalink) Old 11-10-2010, 01:56 PM
Quoted: 0 Post(s)
i got energy suspension's kit i came with a description, i didn't see any instructions however. do you need to press out the old bushings because they were stuck to the LCA or because of somethings else? and as for the torque specs is in not important enough to really need them torqued i would have thought it would be important for the handling of the car to have everything tightened equally and not to overtighten as that would possibly effect the movement. thanks for the help so far though!
User Tag List
Linear Mode Linear Mode
