need to overhaul brakes/suspension need input - Dodge SRT Forum
 5Likes
post #1 of 21 (permalink) Old 06-08-2017, 07:41 PM Thread Starter
finchmeister's Avatar
Quoted: 1 Post(s)
Post need to overhaul brakes/suspension need input
So let me first say that there is a lot of information to cover and I do appreciate using the search function, and have used said function to compile as much mental information as I can retain at this point. This community is super awesome with the plethora of information on hand (Thanks guys). I think I've got most if not all points covered but would still like some input and help with filling in any possible things I need to add or changes I need to make. My car is a 2005 ACR with approximately 99K miles on it, so most if not all rubber bits have gone kaput with these NY winters. My car is a daily driver with 80K of those miles put on it by me and has seen every winter since 2007. She's held up well with little to no problems and has even saved my life on several occasions, i.e. several feet of snow and subzero temperatures; avoided countless accidents, etc., you get the idea. It's time to pay her some serious love and that's where you guys chime in. So now onto the list and soon to be my empty wallet. ;-)
[This is stuff either on or going on car soon]
Suspension:
Energy Suspension Bushing Kit; (front not on yet, rear I have done)
Solid engine/transmission mounts including 4th mount; (not installed yet)
ACR F/R sway bars; (nice and rusty)
DC Sports F/R strut bars; (not installed yet)
ACR Tokico struts; (past their prime)
Brakes:
Calipers OE; (fronts no good, have been sticking need a rebuild)
Power Slot F/R slotted rotors; (front they're shot look at pics, rear are okay)
Pads; (Hawk HPS; pass front melted off, drive front pretty much gone to)
Brake Fluid; (Motul RBF 600)
Brake lines; (squishy original)
[This is possible/future buy; stuff to go on the car; input appreciated]
Suspension:
Hotchkis F/R sway bars #22419
KW Variant 2; (F:340 lbs./in R:170 lbs./in; change them to F:350F lbs./in and R:300 lbs./in?)
Tie rod inner/outer; (MOOG #EV404, MOOG #ES3173RL; do I need a dust boot?)
Rear lower control arm; (MOOG #RK100001 or MOOG #K100001; Mopar #P4510870; SPC Performance #67210, do these have poly bushings?; Bwoody #120.202)
Front lower control arm; (right MOOG #CK620010, left MOOG #CK620009; Mopar *MP #220309-KIT)
*MP – Modern Performance
Brakes:
Calipers; (Power Stop remanufactured w/ powder coating F/R)
Rotors; (OEM F/R #5273141AB, #5085652AB) or
(CENTRIC C-TEK F/R #12163053, #12163054) or
(CENTRIC Premium/Cryo-Treated F/R #12063053/CRY, #12063054/CRY) or
(CENTRIC HighCarb/Cryo-Treated F/R #12563053/CRY, #12563054/CRY)
Pads; (OEM F/R #5086364AB, #5086567AB) or
(CENTRIC C-TEK Metallic F/R #10208410, #10205120) or
(CENTRIC C-TEK Ceramic F/R #10308410, #10305120) or
(CENTRIC Premium Semi-Met F/R #30008410, 30005120) or
(CENTRIC Posi-Quiet Extended F/R #10608411, #10605120) or
*I'm thinking these might be a little excessive for daily driving*
(POWER STOP Z23 Evolution Sport F/R #Z23841, # Z23512) or
*I keep reading good things about these*
(Carbotech Bobcat 1521 F/R #CT841-1521, #CT658-1521)
Brake fluid; (ATE #706202{replaced #706302 I think}, any other alternative to Motul?)
Stainless Brake lines; (Russell Street Legal #694310; Goodridge G-Stop #12408; Agency Power #405 and 410)
Drivetrain:
Wheel hub & bearing; (Front: Mopar OEM hub, Timken Set49 bearing; Rear: Timken #512167)
Axle nut kit; (Mopar *MP #221181-AXLENUTKI, Is it the same for all four? Can't find the part #)
Wheel bearing dust cap; (rear only I'm guessing; possible part #4509396; need input)
Extended wheel studs; (ARP #100-7721 all four corners)
I'll upload some pics of my old lady when I can.
"I know what I'm talking about I've got a power point presentation" -J.J. (Stanley Steemer)
finchmeister is offline
post #2 of 21 (permalink) Old 06-13-2017, 07:49 PM Thread Starter
Quoted: 1 Post(s)
Driver side front. You can see all of the corrosion and rust, along with the snapped stud and broken ground.
Click image for larger version
ID:	132402   Click image for larger version
ID:	132410   Click image for larger version
ID:	132418   Click image for larger version
ID:	132426   Click image for larger version
ID:	132442   Click image for larger version
ID:	132450   Click image for larger version
ID:	132458   Click image for larger version
ID:	132466   Click image for larger version
post #3 of 21 (permalink) Old 06-13-2017, 07:57 PM Thread Starter
Quoted: 1 Post(s)
Driver side rear with all energy suspension poly bushings.
ID:	132482   Click image for larger version
ID:	132490   Click image for larger version
ID:	132498   Click image for larger version
ID:	132506   Click image for larger version
post #4 of 21 (permalink) Old 06-13-2017, 08:04 PM Thread Starter
Quoted: 1 Post(s)
Passenger side front in all of its rusty glory.
ID:	132522   Click image for larger version
ID:	132530   Click image for larger version
ID:	132538   Click image for larger version
ID:	132546   Click image for larger version
ID:	132562   Click image for larger version
ID:	132570   Click image for larger version
post #5 of 21 (permalink) Old 06-13-2017, 08:11 PM Thread Starter
Quoted: 1 Post(s)
Passenger rear and the only thing that isn't messed up really is the caliper.
ID:	132586   Click image for larger version
ID:	132594   Click image for larger version
ID:	132602   Click image for larger version
ID:	132610   Click image for larger version
ID:	132626   Click image for larger version
ID:	132634   Click image for larger version
ID:	132642   Click image for larger version
post #6 of 21 (permalink) Old 06-14-2017, 02:22 PM
SRTforums Admin
stowaway's Avatar
Quoted: 995 Post(s)
Suspension:
Brakes:
Suspension:
Hotchkis F/R sway bars #22419 These are great.
KW Variant 2; (F:340 lbs./in R:170 lbs./in; change them to F:350F lbs./in and R:300 lbs./in?) No need to do the minor change on front rates, but the rear change will balance out the handling of the car.
Tie rod inner/outer; (MOOG #EV404, MOOG #ES3173RL; do I need a dust boot?) No boots needed.
Rear lower control arm; (MOOG #RK100001 or MOOG #K100001; Mopar #P4510870; SPC Performance #67210, do these have poly bushings?; Bwoody #120.202) SPC/Mopar (same thing) are fine as-is. Never been complaints about them. The Moog are interesting adn I haven't seen one in person.
Front lower control arm; (right MOOG #CK620010, left MOOG #CK620009; Mopar *MP #220309-KIT) Don't see the point in new arms if you're already using or wanting to use ES poly bushings. Only benefit would be not needing to press in a new ball joint.
Brakes:
Calipers; (Power Stop remanufactured w/ powder coating F/R) Should be good, but I've been using parts store rebuilds and duplicolor paint if I care about keeping them red. My latest set I didn't care to paint.
(CENTRIC HighCarb/Cryo-Treated F/R #12563053/CRY, #12563054/CRY) For a daily driver I don't see the benefit of expensive rotors. I also don't like slotted or drilled as it just increases pad wear and dust. On a drag race car you want the lighter weight, but on a road race car I'd go with an s-cut or c-cut at most.
Pads; (OEM F/R #5086364AB, #5086567AB) or Great everyday pads but expensive.
(POWER STOP Z23 Evolution Sport F/R #Z23841, # Z23512) or Have had good luck with Power Stop pads on other vehicles
(Carbotech Bobcat 1521 F/R #CT841-1521, #CT658-1521) LOVE these. I don't have working ABS on my car and these allow me to modulate the brakes just the way I need to. Great feel, incredible brake life (last two techs to look over my car have thought the pads were brand new, but they have about 40k miles and multiple stuck calipers on them). Carbotech brakes are very easy on the rotors and the dust doesn't eat at the finish on the wheels. Worth the extra money to me for the front, still running stock rears.
Brake fluid; (ATE #706202{replaced #706302 I think}, any other alternative to Motul?) I run parts store stuff, nothing fancy.
Just flush it every 2 years.
Stainless Brake lines; (Russell Street Legal #694310; Goodridge G-Stop #12408; Agency Power #405 and 410) Stainless is needed. I think I have the Russell lines on my car. One thing to note is to clock the rears away from the tire. I had rubbing on the left rear and had to fix it after a test drive.
Drivetrain:
Wheel hub & bearing; (Front: Mopar OEM hub, Timken Set49 bearing; Rear: Timken #512167) Good choices.
Axle nut kit; (Mopar *MP #221181-AXLENUTKI, Is it the same for all four? Can't find the part #) I've always reused the axle nut hardware, but it's cheap and if yours is rusty, not a bad idea.
Wheel bearing dust cap; (rear only I'm guessing; possible part #4509396; need input) Meh, if you want to.
Extended wheel studs; (ARP #100-7721 all four corners) Only if you need them because of wheel spacers. I wouldn't bother even going to stronger stock length studs unless you are hitting the road course regularly.
notes in red
finchmeister and ziggo0 like this.
stowaway is offline
post #7 of 21 (permalink) Old 06-14-2017, 02:28 PM
SRTforums Admin
stowaway's Avatar
Quoted: 995 Post(s)
And looking at the pictures, definitely replace the axle nut hardware. I'd think about taking a wire wheel to a lot of those parts, sanding them down, priming, and painting while it's all apart. That's a lot of rust. Hit up Modern or a dealer for all of the bolts and adjusters for the control arms. Get new clevis bolts as well, but no need for crash/camber versions, stock will be fine.
finchmeister likes this.
stowaway is offline
post #8 of 21 (permalink) Old 06-14-2017, 07:30 PM
ziggo0's Avatar
Quoted: 159 Post(s)
I assisted a buddy of mine in doing front wheel bearings, ball joints, bushings etc - he had been running just a nut and washer. I told him he really REALLY needs to go get a new spindle nut/kit with all the fixings - like what, 10$ at the parts store? he said no it was fine been running forever like this etc...ok then. He came back from a ~800 mile journey, one nut backed off - tire trashed, wheel damaged, bearing shot, caliper damaged lol. Never not run these parts!
For the rear inner control arm bolts - do we even have a source for these?
Stone White 05 - Built Bottom End - Built Head - Arias - Eagle - BC - Crane - MPX - DCR - Borg Warner s257sx-e .82 AR T3 - e85 - tons of supporting mods
ziggo0 is offline
post #9 of 21 (permalink) Old 06-14-2017, 08:05 PM
SRTforums Admin
stowaway's Avatar
Quoted: 995 Post(s)
Dealer can get them, or the specs and get a bolt from fastenal. Inner are M12x1.75x242 and outer are M12x1.75x230.50.
HybridKid likes this.
stowaway is offline
post #10 of 21 (permalink) Old 06-14-2017, 08:06 PM
SRTforums Admin
stowaway's Avatar
Quoted: 995 Post(s)
Pn 06502796 and 06503203 respectively.
stowaway is offline
post #11 of 21 (permalink) Old 06-15-2017, 05:22 AM
Quoted: 162 Post(s)
i did the front break lines too.
also, i had poly front bushings and wouldn't do them again, get moog problem solver LCA's -- better product
405hp, 450tq
http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is online now
post #12 of 21 (permalink) Old 06-16-2017, 10:56 AM Thread Starter
Quoted: 1 Post(s)
I was almost certain that, (right MOOG #CK620010 , left MOOG #CK620009 ), both contained (MOOG #K200797 ). As part of the full package. All in all it's way cheaper than the alternative. Plus putting those two parts in would just be easier for me than sourcing the tools necessary to press out the old bushings and save time on labor cost when I bring the car to the shop.
post #13 of 21 (permalink) Old 06-16-2017, 09:29 PM Thread Starter
Quoted: 1 Post(s)
I want to replace my old wheel studs with ARP extended wheel studs because I don't know what the future holds for the car so I want to future proof it until I'm ready to get some new rims. Hopefully by the end of the year I can replace my BBS rims with something a little more economical for tires. Also I've been reading that I need to open up the front hub a tad and the rears quite a bit.
So our front hubs are at 9/16 and our rears are at 17/32:
Having just replaced my front hub and reusing the ARP studs, I can tell you that they don't just " go in there". According to ARP, you have a press tolerance on the knurls. Well after doing some research of my own, ARP suggests an ~.005 press tolerance for steel parts and ~.007 tolerance for aluminum parts. 9/16's is .5625 and the wheel stud specs for the knurled portion is .590. Thats ~.028 clearance and that is not enough. So I had to create a CNC program on the mill to cut a circle pocket in the hub to ~.580. That left anywhere between .005 and .010 tolerance and most of the studs measured out to be .585 due to being previously pressed in to the old hubs. So they do not just "go right in". Don't be fooled or you will wind up ruining your hub/studs. Do it right.
post #14 of 21 (permalink) Old 06-17-2017, 11:25 AM
ziggo0's Avatar
Quoted: 159 Post(s)
I picked these up 5 years ago for the rear outer knuckles to replace one bolt I had to cut short when extracting but never got around to using them. Would the 2mm make a difference if used on the inners? I managed to save all 4 bolts...they mostly had to have their nuts cut off so there isn't much threads holding the current nuts on but it's gone for 4-5 years with no issue torqued to spec. Should probably just get those 230.5mm bolts and do the whole rear end again....
ziggo0 is offline
post #15 of 21 (permalink) Old 06-17-2017, 12:40 PM
SRTforums Admin
stowaway's Avatar
Quoted: 995 Post(s)
so long as you get the nut fully threaded, a few mm long or short won't hurt.
stowaway is offline
User Tag List
Linear Mode Linear Mode
