Old 10-14-2009, 05:55 PM   #1 (permalink)
Big_Daddy's Avatar
Member Number: 35480
Default need help asap!!
hey guys i just installed megan racing coilovers. the pass front tire is rubbing against the adjustment rings. it rubs when/after i make left turns. drivers side is fine. alignment was done by a performance shop. if i loosend the bolts that hole the lower portion of the coilover to the hub and pull it out some and have the alignment redone will that correct the problem? thanks guys im kinda worried because i dont want the tire to blow out on me..
Big_Daddy is offline   Reply With Quote
Old 10-14-2009, 06:16 PM   #2 (permalink)
jnathan68's Avatar
Member Number: 59167
Trader Rating: (43)
Assuming that there was some "gap" to be gained by loosening the bolts, yes, that should help. You will need to have it aligned again and hopefully they can adjust your camber using the camber plates (I believe the Megan has them).
You also can tighten up the collar that is at the bottom of spring as long as you don't put too much tension on the spring.
jnathan68 is online now   Reply With Quote
Old 10-14-2009, 06:26 PM   #3 (permalink)
Big_Daddy's Avatar
the lowest collar wont budge. im going to try an pull out the hub.. thanks
Page generated in 0.12435 seconds with 13 queries
