LCA Help - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-09-2012, 08:35 PM   #1 (permalink)
Flame Red's Avatar
Member Number: 89207
Default LCA Help
So I am getting some wheel hop so I figured I would either buy some LCA bushings or all new LCAs completely since my car has quite a few miles and as far as I know they have never been changed. I have a question though regarding the MPx prices. I was just wondering why it costs $120 for brand new LCAs without bushings. $35 for the bushings seperate. But if you buy the bushings already installed on the LCAs it jumps up to $335. Am I missing something or couldnt you simply buy the LCAs and bushings seperate then just install the bushings on the LCAs yourself? Sorry if this is a dumb question but if someone could clarify that, that would be great.
Full Stage 2 w/toys
3in Exhaust
DSP
AEM Wideband
Flame Red is offline   Reply With Quote
Old 12-09-2012, 09:09 PM   #2 (permalink)
Moyeah's Avatar
Member Number: 81699
Im with you on needing some new LCA bushings. Looks like the 120 is for EITHIER the left or right LCA with a stock bushing installed. So 120+120+35=275. So looks like they are charging about 60 dollars to install the upgraded bushings into new LCAs.
Me personally I am just going to buy the bushings and install them myself. Looks like a pain in the ass but I am not paying a shop several hundred dollars to install 35 dollars worth of parts!
Moyeah is online now   Reply With Quote
Old 12-09-2012, 09:24 PM   #3 (permalink)
Flame Red's Avatar
Hmm..I guess I should read more closely
Full Stage 2 w/toys
3in Exhaust
DSP
AEM Wideband
Old 12-09-2012, 10:00 PM   #4 (permalink)
Member Number: 35677
Default Photos and HD video to the rescue
Flame red - myself and others have posted video and fotos as "how-to" on the front c-arm bushings install with OEM arms.
The photos are for saving your hard-earned burger flipping paycheck dollars.
Just order the prothane bushings and DIY. Or if you prefer the Energy Suspenions bushings.
The c-arms from modern have had their detractors.
ValleyRacer is offline   Reply With Quote
Old 12-09-2012, 10:05 PM   #5 (permalink)
Member Number: 18423
No reason to buy new LCA's unless your current ones are damaged/bent. Just pop in the new bushings (I make that sound easy right?) and you're all set.
burks is offline   Reply With Quote
Old 12-09-2012, 10:53 PM   #6 (permalink)
Flame Red's Avatar
alright thanks for the tips guys. Valley I will definately be checking those videos out when I do the install. Probably won't be until summer since I don't have a garage to work in so I have to do it outside. Just noticed as well that you have to remove the lower motor mount when doing this install. Im guessing it would be a good time to install a solid one (or inserts) once I have that one out?
Full Stage 2 w/toys
3in Exhaust
DSP
AEM Wideband
Old 12-09-2012, 11:05 PM   #7 (permalink)
triangles's Avatar
Member Number: 80981
Yea wouldn't be a bad idea for soild mounts. I did my Lca bushings by my self it took like 2 hours to do the first one cause I didn't read the how to. After that pain I read it and it took like 20 mins for the other side.
05 flame red
bw Stage 3 47lb 20g By Mole'
daily driven
E85
triangles is offline   Reply With Quote
Old 12-09-2012, 11:36 PM   #8 (permalink)
Flame Red's Avatar
Wow 20 minutes! I am hoping to get these things installed within 24 hours let alone 1 hour!
Full Stage 2 w/toys
3in Exhaust
DSP
AEM Wideband
Old 12-10-2012, 12:08 AM   #9 (permalink)
rednblack04's Avatar
Member Number: 84924
You will be able to do it in a day for sure even taking a couple breaks and a trip to the beer store
rednblack04 is online now   Reply With Quote
Old 12-10-2012, 01:56 AM   #10 (permalink)
Default Do it NOW in the nice Pennsylvania mild winter!
The main "thing" is the extraction of the rear most bushing. YOu'll want a hydraulic press or you'll go nutty. Get this organized well ahead of time somehow.
SRT4 Front c-arm OEM bushing removal - YouTube
Pre-trim the smaller OEM phukked up overhang rubber and then it comes right out
Bend this tab down slightly to remove
And other than that, there is nothing intrinsically difficult or insurmountable about the bushing swap. I uploaded the PDF instructions somewhere on this site
Be prepared to re-attach to the steering knuckle - get familiar with how to.
I encourage you do go outside in January in Pennsylvania and have an afternoon project in the warm sun and mild temperatures.
Old 12-10-2012, 09:31 AM   #11 (permalink)
Flame Red's Avatar
SRT4 control arm - YouTube
Thanks for info saves me some time searching! And I may just have to do that with this unusually warm weather we have been having.
Full Stage 2 w/toys
3in Exhaust
DSP
AEM Wideband
Old 12-10-2012, 11:10 AM   #12 (permalink)
Default Salty, rusty or cold snowy climates
Also Flamered as we noticed from another board member, he got screwed with the rusty broken bolt. I suspect it to be the bolt in this photo. So if you are a great lakes person or Atlantic ocean salty air or near rusty snowed over salty roads, this might be the time to get a can of PB Blaster and get every bolt all pre lubed and such. Then completely grease your bolts as you reassemble the c-arms.
Things don't rust where I live they MELT in the summer heat.
Old 12-10-2012, 12:23 PM   #13 (permalink)
Flame Red's Avatar
I guess you can't win no matter where you live. Yeah I was just reading about that too though and I myself don't live very close to either of those however a majority of the cars life was in Michigan near the great lakes, so I should definitely pick up some as a precaution!
Full Stage 2 w/toys
3in Exhaust
DSP
AEM Wideband
Old 12-10-2012, 01:29 PM   #14 (permalink)
triangles's Avatar
It was 20 mins to get bushings out and back in. The second time. To install lca was more time. To get them out I used a bench vice and hit the bushings out. And just took my oxygen and actyline and burned them off once out
05 flame red
daily driven
E85
Old 12-10-2012, 01:48 PM   #15 (permalink)
Default Prevents headaches
For a few dollars to spray the PB Blaster on, it beats having broken bolts. Then if you change your rear c-arms, you could prevent broken or stuck bolts with the PB Blaster.
