LCA bushing trouble - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-22-2013, 10:15 AM   #16 (permalink)
Moyeah's Avatar
Member Number: 81699
Ok thanks. I'll try and take pictures of the other one too tonight. It also looks slightly off
MIC 16g E85
Moyeah is offline   Reply With Quote
Old 01-22-2013, 11:13 AM   #17 (permalink)
intshadeofblue's Avatar
Member Number: 84599
I retract my hypothesis. I'll keep an eye on this thread and if I think of anything else, I'll stop back by.
'05 Silver - DD - 74xxx miles
E85 stock turbo - traction in 3rd is overrated
(Tune courtesy of the wizard known as Nigel/Turbo666)
Looks like stock, goes like stink
Hopefully getting 1/4 times before finishing grad school, but after getting slicks...
intshadeofblue is offline   Reply With Quote
Old 01-22-2013, 05:01 PM   #18 (permalink)
Moyeah's Avatar
Random thought: Could my car being on lowering springs have anything to do with it?
(Doubt it since a lot of people are on lowering springs but I thought I would throw that out there)
MIC 16g E85
Old 01-22-2013, 09:27 PM   #19 (permalink)
Moyeah's Avatar
^That idea is out. Guess Ill just retorque to specs and hope for the best.
MIC 16g E85
Old 01-23-2013, 03:06 PM   #20 (permalink)
Shadow's Avatar
Member Number: 86725
Welcome to the club.
2005 PVK w/ GWA
Forward Motion E1, LCR ported & polished manifold, Tial 38mm wastegate. Powered by: E-85
Tuned by Dave, aka Duster360
Shadow is offline   Reply With Quote
Old 01-23-2013, 07:31 PM   #21 (permalink)
69cuda340s's Avatar
Member Number: 36113
The pictures look they were taken with weight off the front suspension. Prothanes do not have a pretty appearance to them when the weight of the car is off them and the arm is extended all the way down. Put wheel back on car, lower car to the ground, and post up another picture.
69cuda340s is offline   Reply With Quote
Old 01-24-2013, 09:35 AM   #22 (permalink)
Moyeah's Avatar
Ok will do... I retorqued them to spec last night but the bushings still do not look pretty. Just bulging in a different spot now
MIC 16g E85
Old 01-24-2013, 05:22 PM   #23 (permalink)
Moyeah's Avatar
Ok here are the pics of the car with the bushings torqued and the wheels on and on the ground.
LCA bushing trouble-left-lca.jpg   LCA bushing trouble-left-lca-2.jpg   LCA bushing trouble-right-lca.jpg   LCA bushing trouble-right-lca-2.jpg
MIC 16g E85
Old 01-25-2013, 12:35 AM   #24 (permalink)
Member Number: 84530
i hope to burned the bushing off the core and put that insert in there and then put the bolt threw it.
ForBidden is offline   Reply With Quote
Old 01-25-2013, 01:48 AM   #25 (permalink)
Member Number: 35677
Default Definitely screwed up
Moyeah - something went wrong. If you do remove those bushings (I know you will) sent the material back to Prothane and find out if there was a problem with the production batch.
But we must determine what went wrong with your install.
I"ll get photos of mine tomorrow when I have time.
ValleyRacer is offline   Reply With Quote
Old 01-25-2013, 01:49 AM   #26 (permalink)
Default What?
Cuda I'll bet yours don't look like this.
Old 01-25-2013, 09:33 AM   #27 (permalink)
Moyeah's Avatar
So these things are just waiting to fail looking like this I assume... Guess I'll try and get ahold of Prothane or Modern Performance(where I bought them)
Just can't imagine I did anything really wrong when putting these in.
MIC 16g E85
Old 01-25-2013, 10:36 AM   #28 (permalink)
Moyeah's Avatar
Shadow did you have success installing the second pair of bushings or did you go with a different companies bushings?
MIC 16g E85
Old 01-25-2013, 11:38 AM   #29 (permalink)
Shadow's Avatar
Default LCA bushing trouble
Nope, yours look like mine did. I did the install differently both times with the same outcome. Pitch 'em in the garbage and get some real bushings!
I remember when some asshole tried to tell me I had frame damage. Man what a load of stupid f^*ks.
2005 PVK w/ GWA
Old 01-25-2013, 01:55 PM   #30 (permalink)
Default Don't be hasty
While it constitutes a little extra work, at least give Prothane back one sample and a letter and disucss with Modern.
Check PM.
