#1 (permalink) |
Master Avatar Creator ![]() ![]() Join Date: Nov 2010
Member Number: 81959
So this may be a stupid question but I have searched with no luck.
Anyways, I plan on ordering some Koni inserts with in the next couple of days and will be pairing them with the Ground Control Coilover Kit. Now, on GC's website, it has a drop down box to select what shock is on the car. The only option is stock only, but it says will not fit with Koni. Are they talking about the insert or something else because I thought these worked with the inserts. Here is the link for the kit --> Ground Control - Coilover Conversion kit, 03' Dodge Neon SRT Or maybe I'm looking at the wrong thing. Any input is appreciated.
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
you need to call them and make sure they use the correct size parts in the top hat and camber plate assembly.
Alright, that's what I will do then. Thanks
#4 (permalink) |
Maybe another dumb question but I got a friend selling some hotchkis springs. Would it be worth saving the money and getting these springs paired with the Koni inserts or would it be beneficial to get the GC coilovers kit instead?
#5 (permalink) |
SRTforums Admin
![]() Join Date: Aug 2003
Member Number: 3286
I think the hotchkis springs was one of the best options made for the SRT. Doesn't drop a ton, but a very good spring rate, especially paired up with the Koni.
#6 (permalink) |
![]() Join Date: Dec 2006
Member Number: 49564
I went from Illuminas with Hotchkis springs to Konis with GC Sleeves and for autox its a huge difference though my spring rates and specific valving (850/450lb) might have something to do with that
In order to fit the Konis you need to bore the rear upper spring plate to 22mm as the Koni shaft is larger. The thread is M14x1.25 make sure they send you the correct nuts. The nuts for the camber plates are specific to GC. |
#7 (permalink) |
#8 (permalink) |
![]() Join Date: Jul 2004
Member Number: 13844
Calling Ground Control is the best option. They are really friendly to deal with and will always stride to get your setup perfect!
bone-yard-racing - Are you running a front sway bar with that setup? What is your rear sway bar setup? I was thinking of similar spring rates as those next for my car.
"America is all about speed, hot, nasty, badass speed." -Eleanor Roosevelt, 1936
"Gotta be committed to it like a pig is committed to bein' bacon!" - Nascar Commentator "Every time a bird craps on my car, I eat scrambled eggs in my car port to show those b****es what I'm capable of." - Uturner, Circa 1878 |
#9 (permalink) |
Keith at GC is who I talked to he was really helpful (overnighted 3 sets of top nuts for my camber plates after I measured wrong for $0 really great guys!) with that said they dont know much about our cars.
No front bar 24mm JC Whitney/Addico solid rear bar. 245/40/17 R6s in the front 225/40/17 R6s in the rear. Fairly mild camber settings (-2.5F -1.0R) havent checked toe all season The car handles very well in some ways, it transitions (slaloms/offsets) quicker than anything I can find. With that said steady state corners are difficult. Its also very very quick to step the rear out |
#11 (permalink) |
Looks like an ideal autocross setup, but I wouldn't try this on track with hpde.
#12 (permalink) |
![]() Join Date: Aug 2006
Member Number: 45182
That much rear sway and nothing on the front then I am not surprised it is a bit snappy.
![]() That's an understatement. Relative Roll resistance front & rear is off the charts even with the 850lb front springs. You sound like the perfect candidate for PT cruiser knuckles with increased Ackermann.
1025cc Injectors+ E85/GAS Base tunes =$359ADD Boost By Gear to ANY PCM boost control tune $75 E85+Gas Base tune Combo $150*[*Only available for 1025cc Siemens/FIC1100&2150/AGP1200/All ID] PLEASE USE EMAIL!!dave at needlesstorque dot com |
#13 (permalink) |
So, I emailed Ground Control today regarding pairing their coilover kit with Konis and this was the response. I was going to call them today but didn't have the time.
Aaron, We unfortunately do not do a kit for the SRT4 w/Konis due to the inconsistencies in the Koni bodies. Thank you for your interest and I wish I could do something for you. Adam So, my question is, how are people using Koni inserts paired with Ground Controls if they say this isn't an option? Would it still be worth giving them a call? Also, if they stopped doing this, what would be the best option to go with spring wise?
#14 (permalink) |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
