Old 10-15-2009, 10:56 PM   #1 (permalink)
uturner's Avatar
Member Number: 13844
Default inner fender ridge
Anyone notice there is a ridge or what seems like a pinch rail on the inner fender of the front wheel wells. It really stops me from getting a lower ride height. Is there anything I can do about it?
uturner is offline   Reply With Quote
Old 10-16-2009, 07:10 AM   #2 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
grind it down, hammer it, stuff like that.
Old 10-16-2009, 08:19 AM   #3 (permalink)
SRT of the Month
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (25)
If you grind it all out you will lose structural integrity. Cut a few slices in it and hammer over and up against the wheel well.
Old 10-16-2009, 10:09 AM   #4 (permalink)
tenney's Avatar
Member Number: 67959
Trader Rating: (13)
I was able to bend it flat using visegrips and a large sledge hammer.
tenney is offline   Reply With Quote
Old 10-16-2009, 03:26 PM   #5 (permalink)
IE Speed's Avatar
Member Number: 42463
Yep, big hammer here to! I then took and smoothed it up a little with a grinder, zinc primed it and undercoated. Except for the plastic wheel liner taking a beating it does not look to bad.
IE Speed is offline   Reply With Quote
Old 10-18-2009, 01:26 PM   #6 (permalink)
uturner's Avatar
Do you still keep you inner plastic fender piece?
Old 10-18-2009, 07:01 PM   #7 (permalink)
ReDsRtKiD's Avatar
Member Number: 46248
I took my plastic fender liners out cause I scraped all the way though em to that rib anyway.
I heated mine up then got out the BMFH & fucked that shit it up!!@!
New Set-up comin' soon..
6/11/08-5/07/09 91pumpking
ReDsRtKiD is online now   Reply With Quote
Old 10-19-2009, 09:00 AM   #8 (permalink)
SRT of the Month
1LAPSRT's Avatar
Trader Rating: (25)
I cut mine in half and only use the front portion to protect the washer tank and the air cleaner.
NICE Language! trying being a bit more civilized, this isn't the "Cali Section"...
Old 10-19-2009, 11:18 PM   #9 (permalink)
uturner's Avatar
On a rating of how difficult to perform this "mod"; as 10 being ridiculously hard and 1 being too easy. How do you guys rate doing this?
Old 10-20-2009, 12:27 AM   #10 (permalink)
IE Speed's Avatar
If You have a big hammer and are not afraid of swinging it, maybe a 2. Pull wheel off, there is 4 torx bolts and 7or 8 push pins on the plastic innerliner. You should go to Kragens or some such place and get replacement push pins, some will undoubtedly brake when You remove them. Easy way would be to cut the folded metal seam, and then use the afformentioned big hammer. Then use a primer for use over bare metal on any exposed bare metal, to keep the rust to a bare minimum. bingo!
Old 10-20-2009, 01:24 AM   #11 (permalink)
uturner's Avatar
Now, in my mind, when you say cut the metal seam. I think as cutting the metal seam into two or three segments to allow them to fold over easier when hammering.
Will this method lose structural rigidity?
Do you primer only the metal seam or everywhere metal is exposed. (that was previously covered by plastic.)
Also, how many segments did you cut the metal seam into. like 3-4 segments or like 8-12 little segments.
Old 10-20-2009, 05:56 AM   #12 (permalink)
SRT of the Month
1LAPSRT's Avatar
Trader Rating: (25)
Like Speed said....maybe a 2.
I would do probably 2 or 3 cuts. Mostly around the curving area.
Page generated in 0.16584 seconds with 13 queries
