Old 02-12-2005, 08:20 PM   #1 (permalink)
NorwayGT's Avatar
Member Number: 15050
INFO: what are the spring rates for all the lowering springs - Answers
stock is Front 170lbs, and Rear 120lbs
hotchkis are 230 front and 200 rear
what are the rates of tien's, eibach's, and all the others?
1.9 60ft 12.9@106 266hp 333.5tq
S1, mbc, agp wga, 3 inch dump TB, ngk plugs, msd wires, boomba MM's, dynoworks tranny mount, hochkis springs, tokico illuminas, hotchkis sway bars, DC front/rear strut tower bars, mopar STS, booger shifter bushings, MBmotoring 16x7's, 225/45/16 kdw's
NorwayGT is offline   Reply With Quote
Old 02-13-2005, 08:24 AM   #2 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
search, there is a thread here with them all listed
Old 02-13-2005, 08:39 AM   #3 (permalink)
bodizapha13's Avatar
Member Number: 10558
Trader Rating: (17)
Manufacturer Front: Rate, Drop / Rear: Rate Drop
Stock: 170 125
Hotchkis: 230 15/16" / 200 1 3/4"
H & R:
Eibach: 1.6" / 1.8"
Tein H: 173 1.2" / 168 1.5"
Tein S: 201 1.8" / 196 2.0"
Progress: 190 1.8" / 150 1.8"
GoldLine: 175 1.5" / 125 1.5"
bodizapha13 is offline   Reply With Quote
Old 02-13-2005, 11:04 AM   #4 (permalink)
SRToc Member
leadfoot's Avatar
Member Number: 5095
Default A little more info for ya
NEX coilover UPDATES thread
IPP Coilovers-
336 front 224 rear comes standard with kits.
Spring options- 448 front 336 rear and 672 front 448 rear
Stage 2-3 Same springs-
According to Marcel Horn at KW suspensions, the fronts are 250 pounds and the rears are 167 pounds.
Here some spring relacement #s;
Manufacturer Front Rate Drop Rear Rate Drop
Dodge stock 170 125
Hotchkis 230 15/16" 200 1 3/4"
H & R
Eibach Progressive rate 221-238 2” 156-168 2 ½”
PRO-KIT 1.6" / 1.8"
SPORTLINE KIT 2.0" / 2.4"Tein H 173 1.2" 168 1.5"
Tein S 201 1.8" 196 2.0"
Progress 190 1.8" 150 1.8"
GoldLine 175 1.5" 125 1.5"
UPDATE- Tokico Illumina Kit
Quote: Originally Posted by toothpickdude
for any of those wondering, i called up tokico and they said the fronts are 155 nm and the rears are 200nm. the drop is 1.5" up front and 1.8" in back.
leadfoot is offline   Reply With Quote
Old 02-13-2005, 07:59 PM   #5 (permalink)
NorwayGT's Avatar
thanks
Old 02-18-2005, 09:55 PM   #6 (permalink)
BigMac's Avatar
Member Number: 18060
Bump -- no #s for the Mopar S1 springs yet?
Black 04
BigMac is offline   Reply With Quote
Old 02-24-2005, 04:23 PM   #7 (permalink)
Member Number: 23236
Trader Rating: (21)
Anyone??
mamador is offline   Reply With Quote
Old 02-24-2005, 05:26 PM   #8 (permalink)
selp's Avatar
Member Number: 7528
Trader Rating: (13)
so which are the best recommended springs to buy out there? ..
selp is offline   Reply With Quote
Old 02-25-2005, 12:47 PM   #9 (permalink)
Member Number: 12670
get one of each it will ride like a dream
I have mods...but then again my warranty is 12.8@107
JimmyWag is offline   Reply With Quote
Old 03-09-2005, 08:11 AM   #10 (permalink)
Member Number: 13838
bump for mopar stage 1 rates
happycnty is offline   Reply With Quote
Old 03-09-2005, 08:58 PM   #11 (permalink)
SRToc Member
leadfoot's Avatar
Member Number: 5095
In all my searches for spring rates I found a lot of them saying that Mopar does not publish thier spring rates. As I posted above KW was quoted from another thread that I found, not Mopar, so good luck finding what thier spring rate is for replacement springs. I don't even know who's spring they use for S1. But you might find that out by using the search button and a little inginuity.
Old 03-11-2005, 01:11 PM   #12 (permalink)
Member Number: 5851
one thing about the Tein H-tech springs, they advertise the fronts at being around 170 lbs , which is what the stock springs are. But I can tell you that the front H-techs are much stiffer than 170 lbs, they are much stiffer than stock, I'd say they are approaching 200 ft lbs as a best guess. They certainly are not 170 lbs which is the same as stock springs. I would say the rears are approaching 170 lbs , but definitely not the fronts. Tein advertises a certain drop and a certain sprnig rate on the H-techs but they are off on both counts , you get a much lower drop than advertised and a stiffer spring rate than advertised, mostly on the fronts.
I am now running the Mopar springs, I'd have to say the spring rates are only slightly higher than stock springs, not a big difference in that regard. So perhaps in the 180 lb range, and maybe 140 or 150 lbs on the rears. not a big difference in stiffness, with a mild drop. The front drop is more than advertised thogh, it is a 1.25 inches drop on the front, right around one inch in the rear.
EBP 04 SRT-4.
JSRT4 is offline   Reply With Quote
Old 03-11-2005, 01:26 PM   #13 (permalink)
tomsrt4's Avatar
Member Number: 2065
How much did you pay for the mopars and are you using the stock struts or aftermarket ones?
CSC #19
tomsrt4 is offline   Reply With Quote
Old 03-11-2005, 01:31 PM   #14 (permalink)
Trader Rating: (21)
Is there still alot of lift in front & squat in the rear while at full throttle acceleration?
Old 03-11-2005, 01:33 PM   #15 (permalink)
Can anybody with access to a spring dyno confirm this?
Page generated in 0.32191 seconds with 11 queries
