Old 06-30-2007, 01:12 PM   #16 (permalink)
SRT4R's Avatar
Member Number: 35481
Wink
Quote: Originally Posted by DaFlyyOnDaWall
any ideas on when IPP changed their spring rates? i have their stage 2 coilovers and am looking into changing the springs on them.
Good idea... The stocker are to soft anyway especialy on the back! Put the 258lbs stocker front on the back and buy a pairs of 345lbs for the front... This is a nice set-up for the track and daily friendly on the street at low cost!
Have a good my friend...
SRT4R is offline   Reply With Quote
Old 06-30-2007, 02:10 PM   #17 (permalink)
DaFlyyOnDaWall's Avatar
Member Number: 14318
are you saying i should swap springs on the stock struts?
DaFlyyOnDaWall is offline   Reply With Quote
Old 06-30-2007, 08:29 PM   #18 (permalink)
SRT4R's Avatar
Thumbs up
You talk about getting the Mopar S2 coilover who come with 258lbs front and 171lbs rear... You just swap the 258lbs to the rear and buy a set of 345lbs for the front! I think it's the best set-up for the S2, because it's a non-adjustable damper so keep in mind you cannot play with the damping to go little bit softer in this case like the S3 coilover who is single adjustable damper so be very conservative in your spring-rate choice...
The S3 coilover is arround $300 more, but offer you a single adjustable damper like I already said... That option give you more little bit room to play with your spring-rate! The best set-up for the track with the S3 is 402lbs front and 287lbs rear, but I don't suggest you to go higher than that if it's a daily driver... It's only a single not a double ajustable damper like the road racer S3R! You can do the same set-up like the S2 also I just mention, 345lbs front and 258lbs rear and buy only one pairs of 345lbs for the front... It's a better daily friendly on the street too!
The best spring upgrade for the stocker is probably the Hotchkis 230lbs front and 200lbs rear... It's nice low cost set-up who make a huge difference compare to the stock spring!
I hope it's gone help you... Have a good day my friend!
Old 07-10-2007, 06:20 PM   #19 (permalink)
i was actullay refering to IPP's stage 2 (which I own) and stage 3 (which has a newer spring rate). but i like your suggestions i may be able to apply them to my CO's. Now if I could just get my rear driver CO un frozen. The sleeve is rusted to the strut body.
Old 07-17-2007, 06:27 AM   #20 (permalink)
DAN_3KVR4_SRT4's Avatar
Member Number: 28874
Should list which offer pillowball mounts with Camber plates too. Good info there.
Also, a poll to which coilovers are the absolute best for the car. Best mix between Street/Strip/Road Course driving. Which one handles these three factors the best.
11.7 Drag Pass CARDOMAIN MOVING TO ITALY AUGUST 08!
DAN_3KVR4_SRT4 is offline   Reply With Quote
Old 07-17-2007, 02:06 PM   #21 (permalink)
njshift's Avatar
Member Number: 5417
Listing camber plates is not a bad idea, I'll see what I can do.
I would recommend making another thread with a poll discussing that above question. I'm trying to keep this thread as a simple way for members to find some basic specs on all the different coilovers available for our cars.
njshift is offline   Reply With Quote
Old 07-18-2007, 11:18 AM   #22 (permalink)
K, kool. Keep up the good thread man, great info.
Old 10-22-2007, 06:54 PM   #23 (permalink)
darcside's Avatar
Member Number: 26402
Thanks for this thread, Good info.
I just saved a ton of money on car insurance by fleeing the scene of the accident...
darcside is offline   Reply With Quote
Old 11-28-2007, 10:44 AM   #24 (permalink)
JBSSRT-4's Avatar
Member Number: 53388
Do you recommend a book or site that will give you the "low down" on how coilovers work? How to work them? I know it sounds easy but a good overview would be great.
JBSSRT-4 is offline   Reply With Quote
Old 11-28-2007, 11:25 AM   #25 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
There's not much to it, really. And different designs can make adjusting one style completely different than adjusting another style. Coilovers work just like normal struts and/or shocks do. They just usually offer more adjustability in damping rates and the ability to change spring rates and vehicle ride height.
Old 12-03-2007, 12:08 PM   #26 (permalink)
gottasrt4's Avatar
Member Number: 57792
suspension
this's an AWESOME thread - I wondered what my spring rate was!! I tell ya someth'n else I'd love to have on here: camber adjustments and how they affect tire wear, performance, etc....etc. THAT'D be awesome!!!
My Car Domain
Kill List:
2004 Mustang GT with a Badass flowmater exhaust - eL skiNNy bUeno drive'n
Hunting:
Porsche Boxster S, Camaro SS, Mustang Cobra, S2K, M3
gottasrt4 is offline   Reply With Quote
Old 12-03-2007, 12:28 PM   #27 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
Camber does not affect tire wear by itself, unless you are over -3°. The increased tire wear usually comes from having the toe out of spec. This causes the tire to basically drag across the road as you drive along. More negative camber helps make the load go across the tread evenly when cornering, but in a straight line this puts less rubber on the road, hurting straight line grip. Your camber and toe change as your suspension travels up and down. This means that as you launch you lose negative camber and the toe changes. If you are only intersted in straight line performance you would want to actually jack the front of the car up a tad when on the alignment rack to simulate the weight transfer when launching and make it basically 0° camber and 0 toe. If you are interested in better handling you will want a completely different alignment setting and even then your best alignment setting will be different if you do road course stuff or autocrossing. Autocross alignments can get away with a very unstable back end, which is not something you'd want when going 120+ on a road course.
Old 12-23-2007, 11:58 AM   #28 (permalink)
DrRafy's Avatar
Member Number: 14422
What about the D2 Racing Sports RS Coilovers? does anybody using this ones? what are the Spec. on the springs?
Mopar S2 w/o Toys, Mopar Short Shift, Mopar Catback, Mopar Tail lights, Ingen Short Ram Intake, Greddy Turbo Timer, JMB Oil Catchcan,MSD Ignition, MSD Wires, NGK Plugs, JMB Powder coated Upper & Lower Pipe with HKS SSQV BOV, Megans Coilovers, ACT Xtreme Clutch with a billet flywheel, Optima Battery, Full Leather Interior, Pioneer 6*9 330w, Pionner 12CD Changer, SoundStorm 2 10" 600w, JVC AMP.
www.myspace.com/rafysoto
DrRafy is offline   Reply With Quote
Old 12-24-2007, 07:37 AM   #29 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
The D2 is just another SE Asian cheap coilover with the same specs as the early IPP, Megan, BG, etc.
Old 12-27-2007, 07:17 PM   #30 (permalink)
njshift's Avatar
Member Number: 5417
Exactly, thanks Stowaway.
I'll see if I can post up the spring rates for whatever it's worth.
