Old 01-06-2007, 12:05 AM   #61 (permalink)
rudedog's Avatar
Member Number: 46929
Go to the auto parts store rather than hardware store. Auto parts ussualy have harder bolts. Specially if you dont know what to look for. As far as torque.....I don't know the spec but all I did is bottom out the bracket then tightened it about 15-20 ft/lbs and it was fine. Oh I know you gonna like it and drool at how flat the car will be.
By the way...what struts are you running? Do you have the Illuminas?
rudedog is offline   Reply With Quote
Old 01-06-2007, 12:08 AM   #62 (permalink)
05'srt-4acr's Avatar
Member Number: 48978
Thank you very much, I think that should do it, Now just have to go down to the parts store in the am. and get the tap kit to remove the one I fucked up. I cant wait to drive it. I need everything I can get to keep the car planted, just spins and spins.
05'srt-4acr is offline   Reply With Quote
Old 01-14-2007, 01:43 PM   #63 (permalink)
Member Number: 48537
with the welfare setup do can u use the bushings that they sell on the website or should i buy better ones.
PTP Wga and Jmb cold pipe/Greddy RS Bov.
My website Adiamsanchez.com
http://www.flickr.com/photos/16534621@N08/?saved=1
atmsanchez is offline   Reply With Quote
Old 01-14-2007, 02:36 PM   #64 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
you can use the ones from dodge for that bar. just put a little bit of grease on it if you are worried about squeaks.
Old 01-19-2007, 04:24 PM   #65 (permalink)
Jattsrt4's Avatar
Member Number: 36263
Sorry if anybody posted this, but what is the chrysler part # for the ACR REAR SWAY BAR. Thanks.
Jattsrt4 is offline   Reply With Quote
Old 01-19-2007, 06:23 PM   #66 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
did you read the first post?
*Part numbers are as follows: Front-5085656AA / Rear- 4656855AA
Old 01-19-2007, 06:57 PM   #67 (permalink)
Jattsrt4's Avatar
yeah I got it thanks.
Old 01-31-2007, 10:08 PM   #68 (permalink)
Jattsrt4's Avatar
Okay, I was wondering if anyone is using energy suspension endlinks, endlink bushings, and/or rear sway bar bushings. I don't know if I should get greasable or non greaseable bushings and what diameter bracket I should get. I am going to install a ACR rear sway bar and I will be lowering my car. If anyone recommends a specific part # for any of the above suspension components that will be appreciated. Thanks.
Old 02-06-2007, 10:01 AM   #69 (permalink)
Member Number: 42667
Just wondering, but some 2005 PT GT convertables use a 27mm front sway bar. Is anyone using this bar?
The one listed in the above posts is a 26mm. I checked the part numbers, and they are different.
05plsrt4 is online now   Reply With Quote
Old 02-06-2007, 10:09 AM   #70 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
I wouldn't do it, too much understeer.
Old 02-14-2007, 02:09 PM   #71 (permalink)
lilredsrt's Avatar
Member Number: 41408
has anyone heard of the uro front and rear from dodge cause i ordered the rear today and i am hoping that its not the same as stock. The part # is 4656511AB if anyone knows please pm me! If the stock part # was on here i would not have ask this.
thanx
273 HP 315 lb TQ @ 20 psi and 13.2@103mph before/ now fully built mammoth combo,map clamp,ptp 75-80 fpr mod and mpx 3'' o2 housing and RFL blow off 325hp 444tq
lilredsrt is offline   Reply With Quote
Old 02-14-2007, 04:35 PM   #72 (permalink)
lilredsrt's Avatar
ok im assuming that they can just hire a bunch of retards at the dealership that i ordered this sway bar from. and the part # above just happends to be the stock sway bar. which is the same as uro also called compitition. so if anyone else goes thru this dont be fooled.
Old 02-14-2007, 04:35 PM   #73 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
huhwhatnow? I don't get what uro is.....
Old 02-15-2007, 08:56 AM   #74 (permalink)
lilredsrt's Avatar
yea i feel the same uro is european. im asuming thats what they get in europe wich is the same as a baseline srt-4. the parts guy called it a european compitition rear sway bar it was 67$ so i was like ok get it but after searching and calling other dealerships i found out its the same as the one on my car. there is no difference between the two.
Old 02-19-2007, 07:07 PM   #75 (permalink)
jmr
jmr's Avatar
Member Number: 10652
Anybody know what the part # is for the stock srt front bar?
jmr is offline   Reply With Quote
Page generated in 0.87079 seconds with 11 queries
