Old 02-03-2005, 05:45 PM   #16 (permalink)
cali's Avatar
Member Number: 159
Quote: Originally Posted by Dale Seeley
Spilner does... I'm betting he's got ghetto springs from Eibach on there...
Or, someone slotted his struts, or someone installed crash bolts... can't think of what else would cause it...
I couldnt tell with the way he was abusing TGPR. Could be those 'bent' rims that he bought too
So his issue is that stock camber is out of spec? Anything could cause this....
Fooked lat link, slightly bent strut? Fat people breaking down the spring, causing it to sag? Abused and used rims
someone is watching me
Old 02-03-2005, 05:53 PM   #17 (permalink)
haljensen1's Avatar
Member Number: 2121
Accidents; hit a curb with the bottom of the tire = positive camber
" " get hit by a car bumper on the top of the tire = negative camber
Ask Leo about negative camber from an accident. Only visisble damage was a scuffed wheel on two spokes.
haljensen1 is offline   Reply With Quote
Old 02-04-2005, 05:30 AM   #18 (permalink)
Mopar Event Specialist
Dale Seeley's Avatar
Member Number: 150
Very strange indeed.... I forgot to measure ride height, I'll have to do that tonight...
I have to rule out impact damage, both sides are showing negative camber in equal amounts, so it's gotta be the springs or somebody installed crash bolts... I think....
Cali, you're right though, somehow he bent one of those SSR's... damn Street Ricers...
Street Ricers Unite! We've been persecuted too long.
Dale Seeley is offline   Reply With Quote
Old 02-04-2005, 06:57 AM   #19 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
I have -.7° in the rear since day one. One dealer wanted me to buy crash bolts for the rear to fix it, I didn't go for that and just left it. No wear problems showing on the factory tires for 8k miles or the new ones for the past 5k. I wish I had that much in the front from the factory.
Old 02-07-2005, 11:07 PM   #20 (permalink)
SRT-4 Technical Disscussion Moderator
Shifty's Avatar
Member Number: 19343
Trader Rating: (57)
Default Ase Master Tech
i have aligned 3 srt4 's and mine and i have seen that the rear camber from the factory is - 1.25 to - 1.45 degrees . But the factory listed specs say other wise? i put mine on the alignment rack with 20 miles on it ,because normaly the factory likes to set the toe in a little to let it drive really straight.
The camber was at -1.25! i left my my friends car like that cause he had 20k on it and no tire wear ? i wonder it the factory listed spec at wrong?
Hum makes me wonder ! Did they make a misktake ?
T1 Race Development
Tuned By Tony Palo
Shifty is online now   Reply With Quote
Old 02-08-2005, 01:28 AM   #21 (permalink)
Member Number: 18836
Trader Rating: (24)
Who's got the SSR's? And what type? I'm debating the GT1 or GT3. Please hook me some pics if his SSR's are either of those. I've only found 3 rims I like. Those 2 SSR's and the Tenzo R Passion 5, I have never seen ANY of the three on any SRT's. If they are the GT1's please hook me all info. Price, where you bought em, hubcentric size, offset, etc etc. THANK YOU!!!!!
flaguy is offline   Reply With Quote
Old 02-08-2005, 05:21 AM   #22 (permalink)
Member Number: 150
Edit: Apparently flaguy didn't think my response was funny, although I didn't get to see his before it was editted/deleted. In an effort to promote goodness throughout the boards, I'll remove my post voluntarily...
Somebody buy that kid a beer...
Old 02-08-2005, 04:15 PM   #23 (permalink)
SRTforums Admin
ekool's Avatar
Member Number: 1
Flaguy, you need to tone down your posts. Chill.
SRTforums.com - Dodge SRT forums - Covering the SRT4, SRT6, SRT8 and SRT10.
ekool is offline   Reply With Quote
Old 02-08-2005, 05:27 PM   #24 (permalink)
Trader Rating: (24)
Roger that.
Old 02-09-2005, 10:10 AM   #25 (permalink)
cali's Avatar
Member Number: 159
damnit, I missed the good stuff....
Old 02-15-2005, 12:42 PM   #26 (permalink)
Dr. Who's Avatar
Member Number: 62
Stock (factory) setup at curb height. (full of all fluids)
Front Toe: 0.10 toe in each side +/- 0.10
Front Caster: 2.6 +/- 1.0
Front Camber: 0.0 +/- 0.20
Max front cross camber: 0.40
Rear toe: 0.15 toe in each side +/- 0.1
Rear Camber: -1.0 (in at top) +/- 0.2
The reason is mainly for tire clearance to the wheel arch flange at full jounce - for when you load up 10 sheets of 1/2" drywall at home depot.
2005 SRT-4 ACR, PVK, ARL, GWA, Bangin' Driver...
(The other other woman.)
R.I.P. SRT-4 Extreme Lightweight
Best E.T.: 11.754, Best Trap: 124 MPH, Best 60':1.782
2500 lbs, Stage 3R, Stage 3 Coilovers, StopTech's, Brass Balls, 369 FWHP, 383 FWTQ - UNTUNED
Dr. Who is offline   Reply With Quote
Old 02-15-2005, 12:45 PM   #27 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
the front camber should have been 0.5° +/- 0.5° with a max cross camber of 0.4°
just my opinion of course
Old 02-15-2005, 12:46 PM   #28 (permalink)
Dr. Who's Avatar
Member Number: 62
Mine too..... Higher powers said otherwise.
That's why man invented die grinders.
[EDIT] Actually, I wanted -1.0 +/- 0.2 max cross of 0.4
Old 02-15-2005, 12:47 PM   #29 (permalink)
Member Number: 150
Interesting....
Old 02-15-2005, 01:11 PM   #30 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
yeah yeah yeah, lawyers said "thoust shall understeer"
man may have invented die grinders, but THE man won't allow that in the rules
