11-25-2006, 07:36 PM
#16 (permalink )
Super Moderator
Member Number: 19761
Great info, I stuck the thread
Thank you for your hard work
Need Boost
12-19-2006, 04:46 PM
#17 (permalink )
Member Number: 1604
KYB SM5198 rear strut mount
I ordered 2 of these bad boys, filled them with RTV silicone and FINALLY I have SILENCE!!!!!
12-30-2006, 05:54 PM
#18 (permalink )
Member Number: 2695
hrm.. i looked up the pn for the ball joint dust boots.. they keep bringing up 70-74 challanger as the application.. did dcx just reuse the design?
they dont look much like the stockers..
2002 MTX 4DR SOHC 2.0L R/T ~ Going back to stock
AFX FSTB, PWerks RSTB, Tokico HP, Eibach ProKit, Prothane RACE inserts, FF Longtube v2, 2.5" Dynomax, MP STS, Boogers, SRT-4 Seats
1998 MTX 2DR DOHC 2.4L TURBO R/T ~ Motor almost finally assembled
http://www.neontuners.com http://www.detroitneonowners.org
12-30-2006, 07:35 PM
#19 (permalink )
Member Number: 23966
i think i was able to get that number by comapring sizes listed...it's been awhile, i'lll have to check on that one
2005 Dodge Neon SRT-4 ACR; PX8, GWA, ARL
2005 Dodge Neon SRT-4 Commemorative Edition #142; PW1, PB5, GWA, ARL
01-02-2007, 07:29 PM
#20 (permalink )
Member Number: 2695
i noticed in the prothane bushing kit (that replaces almost all the bushings) includes 2 of each of those (atleast the picture of the bushings had something that looked similar to those.. 2 balljoint boots and 2 tierod boots.. so they could be the same just not the exact design)
01-06-2007, 12:54 AM
#21 (permalink )
Member Number: 18060
Nice list -- thanks for putting it together. You might want to add the tranny mount insert made by
polybushings .
Black 04
01-08-2007, 08:06 PM
#22 (permalink )
polybushings .
good call on the tranny mount insert, i've known about johnny's mounts for some time. good stuff.
01-25-2007, 08:06 PM
#23 (permalink )
Super Moderator
Member Number: 3286
those KYB 235905 are for a lexus rx330, left front in fact. 235906 is right rear.
http://www.kyb.com/catalog/2006_truck.pdf
234905 and 234906 should be the correct numbers for the r/t-acr.
235927 doesn't come up in the KYB catalog, and the other number is for the r/t-acr, not the srt-4.
02-20-2007, 08:22 PM
#24 (permalink )
Member Number: 17219
Inner Tie Rod Socket:
TRW ES3395
Moog EV403
is this the actual inner tie rod itself? car accident bent my pass inner tie rod.. i need a new one
02-21-2007, 07:32 AM
#25 (permalink )
TRW ES3395
Moog EV403
yes, this is the part that threads into the rack and pinion, this is what you need
02-21-2007, 10:36 AM
#26 (permalink )
Member Number: 40785
hello everyone i just got my megan coilovers im installing this on saturday
my question is do i need to get shorter sway enlinks for the rear if so can i use any of these part # thanks alot guys
Sway Bar Link - Rear:
TRW 18229HD
Moog K8848
Energy Suspension 9.8119G Black
Energy Suspension 9.8119R Red
Prothane 19-413BL Black
Prothane 19-413 Red
02-22-2007, 09:51 AM
#27 (permalink )
TRW 18229HD
Moog K8848
Prothane 19-413 Red
all those #are oem equiv.
09-30-2007, 08:20 PM
#28 (permalink )
Member Number: 56976
anyone know where to buy an aftermarket motor mount? and possibly a price?
03' Flame red SRT-4-catchcan,3" needswings DP w/ e-cutout, short ram w/ K&N ,ATP hardpipe w/ TurboXS RFL,Forge wastegate,MSD plug wires, MSD Demon coil,Tein springs, motor mount inserts,3" O2 housing, Blitz FATT, mapclamp, AEM Uego, full Mopar stage 1 upgrade,AGP lower IC hardpipe, EC BFMIC
10-01-2007, 06:21 AM
#29 (permalink )
A2947
Transmission Mount
2.4 Ltr | 4 Cyl | 148 Cid Engine
Trans
A2947
Transmission Mount
2.0 Ltr | 4 Cyl | 122 Cid Engine
Trans
Automatic Trans
A2948
Engine Mount
Rear Left Upper
Automatic Trans
A2949
Engine Mount
Front Right Lower
http://www.pioneerautoinc.com/
this comes from a company called pioneer, not sure in 2.0 tourque are different than 2.4l arms... i would assume "no" but im not 100% sure
10-02-2007, 12:53 AM
#30 (permalink )
Member Number: 40811
what are the correct endlinks for the S&P Handling and Suspension - PACKAGE 1..comes with a 26mm front sway bar and a 19mm rear sway bar, which endlinks do I buy?
Linear Mode
» Site Navigation
> Other Vehicles
