Old 06-21-2008, 12:31 AM   #1 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (29)
Default How to tighten s3 C/O Shaft nut??
Unlike the stock struts, there is no hex stud to hold/turn the shaft while tightening the nut. I tried using my impact but you can see it's still not bottoming out the threads on the shaft.
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,S3 C/O's,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is offline   Reply With Quote
Old 06-21-2008, 05:43 AM   #2 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
you need to use a vice grip on the shaft but make sure you keep either a shop rag or a piece of rubber between the teeth on the vice grip and the shaft. you don't want to damage the shaft but you need some way to keep it from turning.
Old 06-21-2008, 07:31 AM   #3 (permalink)
njshift's Avatar
Member Number: 5417
Vice grips and a piece of hose worked very well for me. Really try to keep the spinning of the coilover shaft to a minimum, otherwise you can damage the internal seals.
njshift is offline   Reply With Quote
Old 06-21-2008, 08:20 AM   #4 (permalink)
Outlawnick's Avatar
Member Number: 38675
Trader Rating: (86)
Another option would be to use a strap wrench. That way there is no chance of messing up the shaft. Works great!
Click for mods & pics
2004 NSRT-4 AGP DBB 50 Trim
2005 NSRT-4
Outlawnick is offline   Reply With Quote
Old 06-21-2008, 08:51 AM   #5 (permalink)
valeriekay_2000's Avatar
Member Number: 27795
Trader Rating: (28)
Yep, Vice grips worked for me
valeriekay_2000 is offline   Reply With Quote
Old 06-21-2008, 08:52 AM   #6 (permalink)
Member Number: 11814
Trader Rating: (90)
And the correct tool if you want to spend $$.
Strut bearing tool pricing
Old 06-22-2008, 10:23 PM   #7 (permalink)
SRToc Member
gargoile's Avatar
Member Number: 931
For $36.00 you can buy this kit K-D Tools 41720 - 8 Piece, Master Sensor Socket Kit
I used the 7/8's open sided socket ( third item from the left) and used a 10mm wrench to grab the top of the coilover and make sure the nut was tight. Worked like a charm.
2003 Silver SRT-4, Stage 2 (#2), S3 Coilvers, ACR rims, CBD CF hood.
How many of our country's problems could be solved – and solved quickly – if politicians were more worried about what is good for our country rather than how to protect their positions of power?
gargoile is offline   Reply With Quote
Old 06-23-2008, 05:25 AM   #8 (permalink)
Trader Rating: (90)
Nice find so as to keep the costs low.
Old 06-23-2008, 05:42 AM   #9 (permalink)
SRToc Member
gargoile's Avatar
Member Number: 931
Plus you may always have a need for the other 7 sockets and not have to pay $90 per socket More tools for the toolbox
Old 06-23-2008, 12:00 PM   #10 (permalink)
Trader Rating: (29)
turbojack that first tool you listed... I don't think it would work. The S3 c/o's do not have a normal hex pattern on the tip of the strut shaft. Rather its a round shaft with flats on each side. When I do normal struts like the stockers. I use a spark 3/8" drive spark plug socket (the kind that has a spot to use a wrench on the outside also) and a 1/4" drive socket, with a 1/4" drive extention going through the square drive hole on the spark plug socket. Then hold the spark plug socket on the external hex flats, while using a 1/4" rachet to turn the bolts on the strut shaft.
For the S3 coilovers I just use the rubber from the strap wrench and put a vise grip over that. Worked like a charm.
Page generated in 0.25437 seconds with 11 queries
