Old 10-29-2009, 08:08 PM   #1 (permalink)
Member Number: 64577
Default How to change the brake fluid?
I looked but couldnt find anythin on how to do it? Can someone point to a how to?
STILL GH3Tt0 is offline   Reply With Quote
Old 10-29-2009, 08:32 PM   #2 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
do you know how to bleed the brakes? Just keep doing that until you get fresh, clear fluid then go to the next caliper. Every couple of cycles of cracking the bleeder check the master cylinder and top the fluid off.
Old 10-30-2009, 10:19 AM   #3 (permalink)
isnt there a specific caliper to start on? I think the passenger rear? then driver rear, then passenger front the drivers front? Thanks for the help
Old 10-30-2009, 10:29 AM   #4 (permalink)
stowaway's Avatar
Member Number: 3286
left rear, right rear, left front, right front.
Old 10-30-2009, 12:55 PM   #5 (permalink)
I know this is a dumbass question and ill prob get flamed for it, but what side is "left" Ima assuming passenger....???
Old 10-30-2009, 12:56 PM   #6 (permalink)
stowaway's Avatar
Member Number: 3286
left = driver
Old 10-30-2009, 01:03 PM   #7 (permalink)
thank you sir!
Old 10-31-2009, 11:24 AM   #8 (permalink)
SPCorBUST's Avatar
Member Number: 4476
Trader Rating: (13)
never bled the brakes before, only changed the pads. how do you bleed our cars? (minus the aforementioned clear fluid since i've already read that now)
SPCorBUST is offline   Reply With Quote
Old 11-01-2009, 06:41 PM   #9 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (40)
its always good to learn something new and perform the work yourself, but if you decide not to attempt the bleed on your own, a brake shop can do a complete brake fluid exchange for farely cheap.
<-----Haz 1 Infraction for too large of a Signature.
Old 11-01-2009, 10:04 PM   #10 (permalink)
Member Number: 70589
use speed bleeders and bleeded the brakes, all the time like i do-that way the bleeders don't stick into the calipers and you all ways have clean fresh brake fluid.
Sunofwolf is offline   Reply With Quote
Old 11-03-2009, 01:25 AM   #11 (permalink)
Member Number: 75497
i would suggest dont try to bleed brakes yourself. it seems you have to perform it first time. go to some service shop and ask for the brake fluid. they will do all by themselves. its not expensive.
brakes are always to be pondered
crug75hid is offline   Reply With Quote
Old 11-03-2009, 05:27 AM   #12 (permalink)
glhs837's Avatar
Member Number: 215
You can do it yourself, but try like hell to get an experienced hand to help you that first time, and when your done, make damn sure you test the system in a safe manner, dont load up the family and head out for the Tail of the Dragon.
Stow, I think you messed up. Always start with the one farthest away from the master cylinder, which, unless the car is a right hand drive, is the rear passenger side. Then the drivers side rear, then passenger side front, then drivers.
1. Passenger side rear
2. Drivers side rear
3. Passenger side front
4. Driver side front.
glhs837 is online now   Reply With Quote
Old 11-03-2009, 06:54 AM   #13 (permalink)
If you do the brakes by your self-speed bleeders will help you. You only need one person with them to bleed the brakes-get four Stainless steel ones if your rich or get the reg ones-they are very easy to use.one way bleeding is simple with no air getting in. Oh and don't forget to paint your calipers red
Old 11-03-2009, 08:20 AM   #14 (permalink)
stowaway's Avatar
Member Number: 3286
Glhs, remember where the brake lines run on a neon? They go down the passenger side so the drivers rear has more line than the passenger rear.
Old 11-03-2009, 10:54 AM   #15 (permalink)
glhs837's Avatar
Member Number: 215
Didnt know that, when I did my pads, it was a simple swap, and the fluid was fine, so I didnt have to bleed them. So, the lines go from the MC to the passenger side, back to the axle, then across?
Page generated in 0.14621 seconds with 13 queries
