Grinding noise when turning the steering wheel left?
This just started yesterday. I heard like a bolt or something hit the bottom of the car but didnt see anything come out the back. After driving 4 hours after that on the high way... When i turn the steering wheel even really really slightly to the left something starts to grind and makes a vibration sounding like metal is touching metal. When i let the car cool off later, i pulled out of the drive way and the left side sounded like it was squeaking. I checked the rotors and on the back side of the left rotor, the brake pad doesnt look like its touching because half of the rotor is covered in the normal glaze and the other half is rust.
What are your thoughts? Thanks
2003 Black SRT-4, "The Black Out"
AGP 50 trim, Turbonetics Wastegate, Turbonetics BOV, JE Pistons, Stage 2 Crowler Cams, LSD Diff, 750cc Inj, Fuel Return, Walbro 255, NGK Plugs, Honed Intake Manifold and Throttle Body, Custom Intake, BFMIC, Custom 3 inch Exhaust from turbo back, Custom Exhaust Manifold, Custom Hot and Cold Charge Pipes, DTEC Tuner, Tein Lowering Springs, Boomba Solid Mounts, Powder Coated Black Stock Rims
