Old 09-10-2009, 10:14 AM   #1 (permalink)
tiger713_2000's Avatar
Member Number: 27088
Default front wheel bearing?!? question
Can it be done at the house or do i really have to have the press that I was told about. only asking cause it looks hella easy.
flame on if you must.
tiger713_2000 is offline   Reply With Quote
Old 09-10-2009, 10:44 AM   #2 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (21)
There are tools you can buy for its removal/reinstallation. Many have used sockets the size of the bearing itself to evenly tap it into the hub/knuckle.
Remove the entire knuckle and bring it (with the bearing) to a shop. They shouldn't charge you more than maybe $30 to press the old one out and press the new one in.
Pensi?
Old 09-10-2009, 10:47 AM   #3 (permalink)
BLKDOUTSRT4's Avatar
Member Number: 36285
ive used slide hammers to pull them while still on the car and sockets and sledge to install....but that was in emergency situations you should always just find a press and do it right or you could damage the spindle then you are really out some money
Quote: Originally Posted by Alpha-Omega View Post
....yeah, I'm gay and staying home this time
BLKDOUTSRT4 is online now   Reply With Quote
Old 09-10-2009, 10:48 AM   #4 (permalink)
so your saying on the top part that i can just tap it out and then tap the new one in?
sweet that's what my thought was too but didn't really have an idea for cost cause the guys at the shop couldn't or didn't want to give estimate if i just brought in the part.
Old 09-10-2009, 10:50 AM   #5 (permalink)
answered my other concern. shop and press it is I can DIY something else.
Old 09-10-2009, 10:52 AM   #6 (permalink)
JPG
JPG's Avatar
Member Number: 41528
Trader Rating: (24)
i got a question for you.. where do you buy your wheel bearings?
Quote: Originally Posted by Pizza Boy View Post
You can solve that with NRA and SWAT while listening to NWA and hooking up your WGA. OMG WTF BFF just STFU and im like IDK.
Mopar s3 w/toys + delta44 =
┌∩┐(O_o)┌∩┐
JPG is offline   Reply With Quote
Old 09-10-2009, 11:40 AM   #7 (permalink)
fail
Old 09-10-2009, 05:56 PM   #8 (permalink)
necal9's Avatar
Member Number: 46270
Trader Rating: (21)
i tried the sliding hammer and FAILED! Now i gotta buy a new spindle. Worked fine on the driver side. Not so much on the passenger side
necal9 is offline   Reply With Quote
Old 09-10-2009, 06:15 PM   #9 (permalink)
rasp's Avatar
Trader Rating: (21)
I brought both of my knuckles to a shop and had them do it. They did both for $30 each and had it done in an hour. Wasn't going to take the chance fucking up the bearings and installing them then have them be bad, or marring the inside of the hub/knuckle.
I also installed my Prothane lower control arms while I was doing this (easy as cake). Got an alignment and I no longer have steering wheel vibration and the car drives amazing.
Old 09-11-2009, 07:42 AM   #10 (permalink)
Ima call around i called one place that wants to charge 45 which isn't that bad i think but i gotta drive 45 mics away. yak thanks for the info peeps!
much appreciated
Old 09-11-2009, 08:41 AM   #11 (permalink)
Member Number: 62234
I was able to get it out with a sledge hammer. I used a threaded rod and some extra heavy duty washers to press the new one in. I did both wheels like this with no issues. Just gotta make sure it stays straight.
gofastsrt is offline   Reply With Quote
Old 11-06-2009, 09:15 PM   #12 (permalink)
Big_Daddy's Avatar
Member Number: 35480
where did you buy the bearings? if i buy a new hub does it come with the bearing preinstalled?
Big_Daddy is offline   Reply With Quote
Old 11-06-2009, 09:23 PM   #13 (permalink)
csx321's Avatar
Member Number: 4534
Trader Rating: (24)
You can get them either way, depending on where you get them and how much you want to spend. When I replaced mine a couple of years ago, I bought hubs and bearings separately at RockAuto Auto Parts and had a shop press them in. I don't remember how much it was, but $30-$40 seems about right.
'04 SRT4, '87 Shelby CSX, '89 Shelby CSX, couple of others
2006 One Lap of America LER Media Crew
2009 Midwest SRT Nationals Attendee
csx321 is offline   Reply With Quote
Old 11-06-2009, 09:35 PM   #14 (permalink)
Fischy's Avatar
Member Number: 20133
Trader Rating: (13)
"Automotive machine shop" in the Yellow Pages should help you to find a shop. My local shop did the press work for $20 per hub, and AutoZone supplied the bearings.
Stage 3, Everything Ported.
Fischy is offline   Reply With Quote
Old 11-08-2009, 08:30 PM   #15 (permalink)
necal9's Avatar
Trader Rating: (21)
pep boys sold me each bearing for 42. Advanced wanted 60
Page generated in 0.15732 seconds with 13 queries
