Old 11-06-2009, 11:55 PM   #1 (permalink)
Member Number: 75413
Default Emergency brake
can anyone help, when i pull my e-brake i have to pull it alll the way up till it slitly engages, is there an easy way or anyway to adjust the e-brake cable. thanks
ToQuick is offline   Reply With Quote
Old 11-06-2009, 11:59 PM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
jack it up and adjust it whith a flat head screwdriver
AGP S256 FS
Old 11-07-2009, 12:14 AM   #3 (permalink)
jnathan68's Avatar
Member Number: 59167
Trader Rating: (43)
^^^^ He is correct. Jack up the rear of the car and get in behind the brakes (crawl under and look at the back of the backing plate). You should see a rubber plug (kinda of rectangular with rounded corners). Pull out the plug and behind it is a star wheel which you should be able to turn with a screwdriver. Don't remember which way you turn it but you just want to do some trial and error to get it to the point where when the brake is off, the wheel turns freely but locks the wheel down when you pull the brake up. You will need to do both sides if you want them to both work.
jnathan68 is offline   Reply With Quote
Old 11-07-2009, 11:37 PM   #4 (permalink)
Member Number: 57435
Default Hereyou go...exactly what you need to do the adjustment
Here you go...
Vehicle wheel must be off the ground to do the job.
Parking lever should be down(not on)
1) Insert a medium size screwdriver through adjustment hole in the LEFT backing plate. Position the screwdriver against the star wheel on the parking
brake shoe adjuster. Using the screwdriver, rotate the star wheel DOWNWARD until a slight drag is noticed when turning the rear tire and wheel assembly.
Then, using the screwdriver, slowly rotate the star wheel UPWARD, backing off the adjuster, just enough to allow the rear tire and wheel assembly to
rotate without the parking brake shoes dragging. Do not back off the adjuster star wheel more than two clicks past the point of no drag. The parking brake shoe-to-drum clearance is now properly set.
2) Insert a medium size screwdriver through adjustment hole in the RIGHT backing plate. Position the screwdriver against the star wheel on the parking
brake shoe adjuster. Using the screwdriver, rotate the star wheel UPWARD until a slight drag is noticed when turning the rear tire and wheel assembly.
Then, using the screwdriver, slowly rotate the star wheel DOWNWARD, backing off the adjuster, just enough to allow the rear tire and wheel assembly to rotate without the parking brake shoes dragging. Do not back
off the adjuster star wheel more that two clicks past the point of no drag. The parking brake shoe-to-drum clearance is now properly set.
Remember to put the plugs back in !
Amoeba is offline   Reply With Quote
Old 11-10-2009, 10:07 PM   #5 (permalink)
chocolate_ninja's Avatar
Member Number: 62731
i was able to fully adjust the left side. but the right side wont adjust anymore. the star wont turn anymore. and when i look at the cables by the shifter, the right side cable is too slack. so do i have to repalce that brake cable?
chocolate_ninja is offline   Reply With Quote
Old 11-11-2009, 10:39 AM   #6 (permalink)
fivetoez's Avatar
Member Number: 9691
You went the WRONG direction when you moved the star wheel.
Try again!
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
Old 11-11-2009, 11:48 PM   #7 (permalink)
no. i went the proper direction. i remember i checked it on the ALLDATA cd. i was able to adjust the left side going in the proper direction. i forget right now if its up or down. but when i did it to the right side, the wheel still spins freely
Old 11-12-2009, 01:29 AM   #8 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
Just for the hell of it I would try going the other direction all the way and see if it gets tighter or looser.
porksword is offline   Reply With Quote
Old 11-12-2009, 08:20 AM   #9 (permalink)
ok, ill try that
Old 11-12-2009, 01:42 PM   #10 (permalink)
ATaylorRacing's Avatar
Member Number: 62238
You can do that and still not have enough e-brake handle....these things end up stretching the cables....I am going through that problem now....I can't even hold it in the water for a burnout at the drag strip. We are jerry-rigging a junk of metal into the handle to take up cable slack at that point since the rears are adjusted all the way.
35 time NHRA/IHRA champ
12.87 @ 110 05 SRT4 stage 2 / DOTs
15.17 @92 05 V6 stock Mustang / wifes
1790 lb 84 Horizon / winningest fwd car
19.84 @ 65 96 Geo Metro 3 banger
ATaylorRacing is offline   Reply With Quote
Page generated in 0.21099 seconds with 13 queries
