E brake shoes - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 04-14-2012, 06:14 PM   #1 (permalink)
Member Number: 86368
Default E brake shoes
Anyone have a DIY on e brake shoe replacement? IV bought the parts but can't find a install process. Iv never had a car with drum brakes so i cant relate it, any help would be appreciated.
Flybye is offline   Reply With Quote
Old 04-14-2012, 08:05 PM   #2 (permalink)
fwdviper's Avatar
Member Number: 82740
I could try and explain but this is easier.... factory service manual will tell you what to do. If you're mechanically inclined you'll be fine it's not hard
http://www.ertyu.org/steven_nikkel/n...pl_intlpdf.pdf
fwdviper is offline   Reply With Quote
Old 04-16-2012, 11:55 PM   #3 (permalink)
JonJon4130's Avatar
Member Number: 86768
Have you visually inspected the pads yet? Only reason I ask is because to get a look at the pads you have done most of the work to replace them if i remember correctly. I thought my pads needed replacement but they just needed an adjustment.
JonJon4130 is offline   Reply With Quote
Old 04-17-2012, 05:58 AM   #4 (permalink)
Turbo Laser's Avatar
Member Number: 87931
The haynes manual gives a good how to. Just go to your local parts store and take pictures. Once you have the car up do one at a time and use the other side as a reference. Get the hardware kit, it'll make your life easier
Turbo Laser is offline   Reply With Quote
Old 04-17-2012, 11:41 PM   #5 (permalink)
Thanks for the response guys. Replaced the rear rotors a month ago and notcied there very little meat left on the shoe. I bought the car used so I'm not sure why they are worn so bad. What is the hardwear kit and do you have a part#? I only bought the shoes but if it makes life simpler than I buy the hardware to.
Old 04-18-2012, 05:30 AM   #6 (permalink)
I'm pretty sure its H7417 using autozone's part number
