Old 11-07-2006, 02:42 PM   #1 (permalink)
Member Number: 42716
Trader Rating: (15)
Default E-Brake not strong enough!
I want to know if there's a way to regulate the Manual brake. I replaced the pads all around I though that would solve my problem. But it hasnt.
If I park the car uphill even just a little bit, then I put the manual brake on, it still rolls back, then I have to do it a second time and pull it harder and it gets some tension. I don't think it's supposed to be like that. Any suggestions as to what's the problem?
I always leave it on gear, but I would like to not have to leave it on gear when Parked in a flat surface.
So, somebody let me know how to regulate it plz...
Nefty_nef is offline   Reply With Quote
Old 11-07-2006, 04:14 PM   #2 (permalink)
19 psi's Avatar
Member Number: 12457
Trader Rating: (39)
uhhhhh you can tighten the tension on the ebrake by turning the little star clockwise or counter-clockwise (cant remember which way but one way tightens and the other way lossesens) its under the rear rotor in the ebrake area. dont know if this is gonna help but you should know if you dont have enough tension in ebrake cuz the ebrake lever will feel real loose.....like its not grabbing on to anything good enough..
mzods:
S3r tial wheel AGP S3 WGA 30psi
bosch 1000cc inj. E85 (HOM everywhere)
KW V2 coilovers
Boomba mounts
CM S3
E46 bi-projector full retro'd headlights
+ every other bolt on
19 psi is offline   Reply With Quote
Old 11-09-2006, 10:26 AM   #3 (permalink)
HotRodDodge's Avatar
Member Number: 26952
You can peplace all the pads over and over and it won't get any better because the parking brake has nothing to do with the pads, there is a set of parking brake shoes under your rear rotor, probly not worn out unless you drive with the parking brake on, they can be adjusted like normal drum brakes.Or like mentioned above just adjust the cable tension.
04 Flame Red SRT-4
89 White Shadow ES Turbo
05 Black Pacifica
HotRodDodge is offline   Reply With Quote
