Old 11-19-2008, 10:52 AM   #1 (permalink)
Member Number: 47916
Default Drop on stock struts
What is a good aftermarket set of springs that will drop the car a mild drop without affecting ride quality that much? will H&R springs be any good? i know mopar makes some, but they are expensive for what they do
thanks,
latief is offline   Reply With Quote
Old 11-19-2008, 11:04 AM   #2 (permalink)
phyber's Avatar
Member Number: 54057
i had a set of Eibach Pro kits on mine, it was a good drop, maybe a 1/4 to 1/2 inch gap between tire and fender. no rubbing issues with stock rims and wider-than-stock tires.
dropped on stock struts with no major issues. car rode/handled good....but when i'd hit a big pothole or bump in the road there would be one loud THUD...
i'd suggest aftermarket struts with the springs, it'll be a different feel as well.
but your stock's should be fine.
05 civic si. k20 power.
i miss my srt4 every single time i press the skinny pedal.
phyber is offline   Reply With Quote
Old 11-19-2008, 11:06 AM   #3 (permalink)
SRTforums Admin
Pete's Avatar
Member Number: 43767
Trader Rating: (89)
Modern Performance Racing Products
those are my favorite
eibach sportlines
ran a 12.11 at 111 on the stock ported turbo 1.68 60ft
NEW SECTION ****SRT OF THE MONTH CLICK ME*****
DRIVE A NISSAN SENTRA NOW SRT IS GONE
Quote: Originally Posted by peteswife View Post
Yes, because Peter takes the interwebs job oh so seriously... oh wait, a job that he doesn't even get paid for!!!
Pete is offline   Reply With Quote
Old 11-19-2008, 11:08 AM   #4 (permalink)
red04's Avatar
Member Number: 24993
Trader Rating: (51)
I recommend the Eibach Pro kit springs. They give the car a good drop, more aggressive stance and they will tighten the ride up some. You can put them on with the stock struts and they will be fine. I have had these springs on for 2 - 2 1/2 years now on the original struts. These are the only springs we recommend.
Scott @ Forward Motion Inc.
302-658-2829
www.forwardmotioninc.com
Email: scott@forwardmotioninc.com
Paypal Address: scott@forwardmotioninc.com
Owner of FM's GT37R powered SRT4 513 whp 469 wtq pump gas (93 octane) @ 6,000 rpms
11.31 @ 131.74 mph w/ 1.90 60'
red04 is online now   Reply With Quote
Old 11-19-2008, 11:11 AM   #5 (permalink)
i've heard people say that the ride quality is bad/ stiff (or progressively worsening as time goes by), did you hear of any issues similar to this?
thanks for the info
Old 11-19-2008, 11:17 AM   #6 (permalink)
SRTforums Admin
Pete's Avatar
Trader Rating: (89)
if you alter the stock struts with lowering springs you are def. going to have a stiffer ride. If you do anything different you will notice a difference. I had hotchis springs on my car and it was stiffer/bumpier then a stock srt. Now i have meghan racing coilovers and it is a lot stiffer and bumpier no matter how soft/hard my damper is, BUT i love the way the car responds and how stiff it is. Handling is 10x better now.
Old 11-19-2008, 11:21 AM   #7 (permalink)
true, i agree and understand...
but some companies do better research on their products to insure better handling, instead of just putting in any shorter and stiffer springs. i would think eibach would be one of them, but i've heard some bad stories.....
any experience with H&Rs ?
thanks for the feedback
Old 11-19-2008, 01:11 PM   #8 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
I have the Eibach Pro Kit and like them.
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is offline   Reply With Quote
Old 11-19-2008, 01:31 PM   #9 (permalink)
hows the ride? and how are your struts holding up?
thanks
Old 11-19-2008, 02:58 PM   #10 (permalink)
04RedSrt-4's Avatar
Member Number: 56795
Trader Rating: (79)
What about the progress springs?
04RedSrt-4 is offline   Reply With Quote
Old 11-20-2008, 04:31 AM   #11 (permalink)
93stang434's Avatar
Member Number: 49690
I've got the eibach pro kit with the stock stuts and it is definitely stiffer then stock but no matter what lowering springs you go with they will be stiffer.I'm getting different struts and i'm hoping it will calm the bounce down a bit
E1 w/ported 3" anti-surge cover,PTP,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Old 11-20-2008, 07:51 AM   #12 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (21)
If you want a good ride with some drop i recommend tein H-techs they can be got for about 180shipped. RIDE great have almost the EXACT same spring rating as mopar stg 1 springs they just drop the rear .5 more. They have been on my car for 20,000 miles now and the car still drives fantasic!
Link to when I had them put on..
Mopar vs tein H tech
Also pics of them with my newest 18" wheels
Tuned By TDSAaron!!
Now Rocking a Delta 46
Old 11-20-2008, 08:30 AM   #13 (permalink)
How are you liking the N5000? I am about to buy those tires....
thanks for the pics ..... drop looks good....
Old 11-20-2008, 08:33 AM   #14 (permalink)
Kason23's Avatar
Trader Rating: (21)
there not the worst I have had..but not the best ether they came with my rim package so I cant complain. Cant hook to great with them at the track is about my only complaint
Old 11-20-2008, 09:10 AM   #15 (permalink)
my_little_srt's Avatar
Member Number: 41179
Trader Rating: (24)
H&R's here and loving it...............
my_little_srt is offline   Reply With Quote
