Quote: Originally Posted by
Big_Daddy
what really is the advantage of coilover to spring/shocks. i meen i can only see they are adjustable. please fill me in?
Here is a little info about the Megan Racing full coilovers:
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
Specs:
Spring Rates: 8kg Front and 6kg Rear
Pillow Ball Upper Mounts
Rubber Dust Covers
Adjustable Ride Height
Aggressive Spring Rates
Single-Cylinder Design
Aluminum Brackets
32 Levels of Adjustable Damper:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
Plus you can run wider wheels and tires.
Springs: $200
Struts: $600
Camber bolts: $40
Shipping: $60 ?
Total: $900
Megan CO's: $750 shipped
BC CO's: $1000 + ship
