Old 10-15-2009, 05:22 PM   #1 (permalink)
Member Number: 70102
Default Do Stage 1 springs need a wheel alignment afterwards?
With stage 1 springs, you don't need to get a wheel alignment afterwards right?
But what if you were to buy new struts to go w/the springs at the same time? Then I'm thinking you would need a wheel alignment afterwards?
If someone knows, I'd appreciate it. Thanks.
Srt4SC is offline   Reply With Quote
Old 10-15-2009, 05:30 PM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
yes you would, if you need camber bolts i have some brand new for 15shipped any time you mess with the suspension you need a alignment.
AGP S256 FS
Old 10-15-2009, 05:34 PM   #3 (permalink)
SRT of the Month
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (25)
What he said!
Old 10-15-2009, 05:44 PM   #4 (permalink)
really, anytime you mess w/the suspension you need an alignment? Cuz i've been told w/the stage 1 springs, you don't have to get an alignment afterwards... i mean it makes sense to me, i'm just wondering if anybody out here would say you dont need to get an alignement done w/the stage 1 springs...
thanks for the input, that sorta changed my mind a little bit.
Old 10-15-2009, 07:36 PM   #5 (permalink)
Member Number: 56053
I have the stage 2 struts on my car and had to send them into KW before for repair. I think basically if you have to loosen anything that has to do with the suspension you will need an alignment after. With the exception of the strut mounting nuts on the top under the hood.
Hotchkis front and rear sway bars, K&N Typhoon CAI, AGP solid motor mounts, AGP solid tranny mount, AGP solid intercooler hot pipe, AGP BFMIC, Mopar stage 2 suspension kit, DC sports front and rear strut tower braces, Perrin catch can, Perrin boost tube with HKS SSQ BOV, Maddog 58% STS, Racing Hart 17X7.5 rims with BFG g-Force T/A KDW 225/45, Stoptech 2 piston BBK, Mopar exhaust.
Killfire is offline   Reply With Quote
Old 10-15-2009, 07:47 PM   #6 (permalink)
svtsrt's Avatar
Member Number: 41942
Trader Rating: (15)
anytime you're touching suspension or related components i.e. struts, tie rods, balls joints, etc. you need to get an alignment.
get the before and after specs so you can see what the differences are.
05 SRT-4
-Mopar stg3, Mopar BOV, sts, exhaust, CTI hotside pipe, JBM cc, Maxxfab dp w/ cat, AEM uego wideband, Aeroforce gauge-
svtsrt is offline   Reply With Quote
Old 10-15-2009, 08:28 PM   #7 (permalink)
kagekun's Avatar
Member Number: 57941
Anytime you change something suspension wise you need to get an alignment. Its not like its expensive to do
Meth Addict & CM is my dealer
http://www.cardomain.com/ride/3219131
kagekun is online now   Reply With Quote
Old 10-15-2009, 08:36 PM   #8 (permalink)
Does stage 1 have a different set of alignment specs than stock? or do they set the alignment to the same specs.
I think I saw where Stage 3 has a different set of specs to align to...
Thanks for the info...
Old 10-16-2009, 07:07 AM   #9 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
moved to the right section......
There is no "right" specs for a suspension, and it doesn't change for different suspension setups. You set the car up for what you want out of it. More negative camber if you want better cornering, less negative for daily driving and drag racing.
And while the s1 springs don't drop a ton so the camber change isn't huge, you MUST make sure your toe is correct so you don't eat the tires alive.
Old 10-16-2009, 10:34 AM   #10 (permalink)
I saw these specs for stage 3 for alignment. I just didn't know if Stage 1 came with an install sheet as well?
Left front Toe: +0.2º toe in
Left front Camber: –1.5º
Right front Toe: +0.2º toe in
Right front Camber: –1.5º
Left rear Toe: 0.0 to +0.1º toe in
Left rear Camber: –0.5 to –1.0º
Right rear Toe: 0.0 to +0.1º toe in
Right rear Camber: –0.5 to–1.0º
From the install sheet.
Old 10-16-2009, 10:37 AM   #11 (permalink)
stowaway's Avatar
Member Number: 3286
no, I don't believe they do. The mopar coilovers have camber adjustment built into them and if you just put the lowering springs on you won't have any adjustments for camber, just the toe.
Page generated in 0.17842 seconds with 13 queries
