If you pick up stock struts from the dealer, most shops will charge you around 1.5-2 hrs labor per corner. None of the usual OE replacement struts are designed for the SRT and are not the correct pieces to get. You either need OE pieces from the dealer or Tokico Illumina struts which run about 650 a set.
