Old 07-22-2008, 09:44 AM   #1 (permalink)
Member Number: 50103
Default Car pulls! please help
Hey guys, I have an 04 srt and it pulls right like a bitch under acceleration. I have the poly bushings and my alignment is pretty close to factory specs. Any ideas what i should do next? thanks ~Jason
04 SRT - AGP 50 trim
65 Factory Five Cobra - Blown SBF
Kingcobra is offline   Reply With Quote
Old 07-22-2008, 09:54 AM   #2 (permalink)
Member Number: 19791
If you done all of the following:
A. Checked tire pressure.
B. Had proper alignment.
C. Checked torque spec on lower control arms.
D. Checked motor/tranny mounts for cracks and problems.
It may be a problem with the poly bushings. I had Engergy Suspension bushings in my car and had the same problem. Took out the E.S. bushings and put stock back in and problem was fixed, end of story.
Billfold00 is offline   Reply With Quote
Old 07-22-2008, 11:31 AM   #3 (permalink)
I put the poly bushings in to try and fix the pull...and it didnt seem to help.
Old 07-22-2008, 12:15 PM   #4 (permalink)
If the problem existed before you installed the poly bushings, make sure you check your motor/trans mounts like I mentioned before.
Did the problem start after you installed any new parts? Wheels? mounts? turbo? etc?
I'm betting it still has something to do with your lower control arms. If all else fails, take it to a reputable shop and see and they can find something. You can also pick up a set of new control arms off Ebay with bushings and ball joints for about $180 shipped.
Page generated in 0.12694 seconds with 11 queries
