Old 07-15-2008, 04:30 PM   #1 (permalink)
Member Number: 30987
Default camber plates question
I searched around on here and found that Mopar doesn't supply the needed bolts for the top of their camber plate where the plate mounts to the body. I read that it's best to use a bolt with an allen head, is that true? Also, what size bolt and how long is needed? The plates are being shipped to me right now and I just want to get everything needed before they get here so I can installed them on Thursday. I can't wait to get rid of my prison rape stance. Thanks in advanced for your help.
Needswings V6 downpipe, PTP check valve, PWERKS 3-point front and rear STB, Rage-tek shifter bushings & cnc'd shifter base, maxxfab o2 housing (damn heatshield bolts ), magnaflow camaro style muffler, Stage 1 pcm, 17x8 5zigen FN01r-c w/ 245/40/17BFGoodrich g-force sport, msd spark plug wires, (ptp fuel pump re-wire, fan-mod switch, innovate xd-16wideband)
Rob at Needswings is one of the best vendors on the whole forums imho.
SRTabc123 is offline   Reply With Quote
Old 07-15-2008, 04:42 PM   #2 (permalink)
htheduck's Avatar
Member Number: 10205
curious as to where the allen head theory comes from...a bolt is a bolt.
allen heads are smaller...but the bolt is still doing the same job.
also curious, what does your prison rape stance (rake) have to do with camber adjustability? I'd have to assume different springs are going in, along with a set of plates...
-Howard
_________________________________________________
94 Taurus SHO: K&N, Eibach/Koni, ATE Super Blue, FPS: Alum SFB, SFC, 96 Brakes/Porterfield R4
94 Integra LS: K&N, Neuspeed/KYB, F&R STB, Rear LTB
04 SRT-4
htheduck is offline   Reply With Quote
Old 07-15-2008, 05:38 PM   #3 (permalink)
yeah i'm getting mopar stage 3 coilovers for the drop. And That's what i thought about the allen head question. I just want to find out how long so that when i close the hood the bolt ends don't hit. It doesn't matter on the rear since they'll just stick up into the trunk.
Old 07-15-2008, 05:47 PM   #4 (permalink)
SRToc Member
gargoile's Avatar
Member Number: 931
I just went to the local hardware store and bought some 3/8 grade 8 bolts and then only had to cut the outside ones so that they didn't hit the hood plate.
2003 Silver SRT-4, Stage 2 (#2), S3 Coilvers, ACR rims, CBD CF hood.
How many of our country's problems could be solved – and solved quickly – if politicians were more worried about what is good for our country rather than how to protect their positions of power?
gargoile is offline   Reply With Quote
Old 07-15-2008, 11:16 PM   #5 (permalink)
Awesome! Thanks for your help.
Are there anymore issue with top bolt that holds the coilover to the camber plate being the wrong size?
Old 07-16-2008, 06:38 PM   #6 (permalink)
SRToc Member
gargoile's Avatar
Member Number: 931
It has nothing to do with the size. If it fits in the hole it will work. Take the plate with you to the store to make sure you get the biggest bolt that will fit in the hole.
Page generated in 0.15257 seconds with 12 queries
