Quote: Originally Posted by
SkullingAxe
Strut firmness set to 8 counts (full hard being 0 according to the instructions) which is suppose to be like stock.
There is your problem. Out of 32 adjustments, you chose 8 from the stiffest. Your fillings should be rattling out of your teeth from that much stiffness.
Turn the adjustment knob counter-clockwise all the way until it stops. that is your softest setting. the count 8 clicks in a clockwise motion. Then you are 8 clicks from the softest setting. front and rear settings at 8 from full soft is a great start for daily driving.
Try that out and check back here to tell us how it went.
