Old 07-08-2008, 11:17 AM   #1 (permalink)
dragradial's Avatar
Member Number: 22291
Default Any ideas how I can lower the rear Mopar stage 1 springs an inch?
Any geto mod I can do to lower the rear springs an inch.
I have the mopar stage 1 springs. The rear is so much higher than the front it bothers me but I am broke and cant do much about it.
Not crazy about the Starski and Hutch look.
dragradial is online now   Reply With Quote
Old 07-08-2008, 11:35 AM   #2 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
nope, nothing you can do that won't drastically hurt the ride and safety.
Old 07-08-2008, 11:46 AM   #3 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (32)
How new are the springs? They do settle more over time..it takes the rear a lit longer because there is way less weight back there.
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,S3 C/O's,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is offline   Reply With Quote
Old 07-08-2008, 12:22 PM   #4 (permalink)
Member Number: 54464
let the struts blow out...
05' Silver Neon.
Stock...
FYI - Long Signatures with a bunch of uselss (or... what everbody has) mods listed is Retarded, Ricer, and Gay.
TheNumberOneD is offline   Reply With Quote
Old 07-08-2008, 08:35 PM   #5 (permalink)
htheduck's Avatar
Member Number: 10205
cutting them is one solution.
but then, (if you did)-why did you purchase them? - obviously not for the height...
i personally would never cut a spring and install it in any of my vehicles. but that's just me.
-Howard
_________________________________________________
94 Taurus SHO: K&N, Eibach/Koni, ATE Super Blue, FPS: Alum SFB, SFC, 96 Brakes/Porterfield R4
94 Integra LS: K&N, Neuspeed/KYB, F&R STB, Rear LTB
04 SRT-4
htheduck is offline   Reply With Quote
Old 07-08-2008, 09:02 PM   #6 (permalink)
Lay
Lay's Avatar
Member Number: 41690
Trader Rating: (21)
spring clamps, they sell them at your local auto parts store.
Lay is online now   Reply With Quote
Old 07-08-2008, 09:27 PM   #7 (permalink)
Trader Rating: (32)
Fat chicks in the back!!
Old 07-09-2008, 09:36 AM   #8 (permalink)
dragradial's Avatar
Fat chicks sound good but it might slow me down.
I might try the spring clamps thanks.
Old 07-09-2008, 09:47 AM   #9 (permalink)
jstbrd's Avatar
Member Number: 10925
carry around something heavy for a few weeks...they will settle. Try an extra set of rims or something.
04 SRT4
Mopar Stage 3 Coils
Stoptech ST40s
jstbrd is offline   Reply With Quote
Old 07-09-2008, 11:03 AM   #10 (permalink)
my_little_srt's Avatar
Member Number: 41179
Or some weights.....
my_little_srt is offline   Reply With Quote
Old 07-11-2008, 10:49 AM   #11 (permalink)
mikeh6's Avatar
Member Number: 14199
Trader Rating: (37)
sand bags in your trunk
mikeh6 is offline   Reply With Quote
Old 07-11-2008, 08:48 PM   #12 (permalink)
BlackOhFour's Avatar
Member Number: 26183
find someone selling just rear springs?
Pittsburgh Crew - Join up: http://www.pittspeed.com
Quote: Originally Posted by RedLineGSR94
you managed to get 8 DSMs together in one place??? did you own a junkyard???
BlackOhFour is offline   Reply With Quote
Old 07-14-2008, 12:10 AM   #13 (permalink)
Member Number: 13195
Default ultimate fix
drive backwards
Qunniq is offline   Reply With Quote
Old 07-14-2008, 12:43 AM   #14 (permalink)
Member Number: 62258
I would buy new rear springs but if you are really desperate, take a blow torch and heat them up. The heat will cause the spring to soften and sag resulting in a lower spring height.
Madisonr34 is offline   Reply With Quote
Old 07-14-2008, 06:16 AM   #15 (permalink)
Member Number: 14149
I have a set of Stage 1 rears you could experiment with.
I bought a full set used but the fronts were hit with a torch so I didn't use the set, rears are pefect.
04 SRT-4
86 GLHT- 13.17@ 95.85
keito is offline   Reply With Quote
Page generated in 0.26884 seconds with 11 queries
