Old 01-16-2006, 05:42 PM   #1 (permalink)
Member Number: 26073
Default Adjusting Parking Brake?
hi, my parking was working great and now it seemed to come loose sometimes it holds fine other it starts rolling backwords and hit a curb....so now i have to fix it before it does more damage. Does anyone know how i can tighten up my parking brake? I was thinking it was on the cable but im not sure. thanks
MikeGreen is offline   Reply With Quote
Old 01-16-2006, 05:50 PM   #2 (permalink)
td1042k's Avatar
Member Number: 17637
Trader Rating: (12)
the parking brake SUCKS ASS in these cars..ive had mine adjusted 3 damn times and has come loose every single time on my car
probably be better off spending 10 dollars on a set of wheel chocks....
td1042k is offline   Reply With Quote
Old 01-17-2006, 12:03 AM   #3 (permalink)
htheduck's Avatar
Member Number: 10205
You will need to pull the wheels, and adjust from the rear similar to adjusting a set of drum brakes.
-Howard
_________________________________________________
94 Taurus SHO: K&N, Eibach/Koni, ATE Super Blue, FPS: Alum SFB, SFC, 96 Brakes/Porterfield R4
94 Integra LS: K&N, Neuspeed/KYB, F&R STB, Rear LTB
04 SRT-4
htheduck is offline   Reply With Quote
Old 01-17-2006, 12:11 AM   #4 (permalink)
cooper232's Avatar
Member Number: 12276
get underneath the rear of the car (i recommend to jack up one side at a time) you will see the back of the drums... pull out oval shaped rubber plug... you are looking at the "teeth" on the side of a gear... push them down until your wheel drags (drivers side) then push it back up one or two where it wont drag anymore. do the same on the other side but push up until it drags and then push it back down one or two notches. just did mine last week. works great now.
need a bumper cover! anyone? anyone? bueler?
cooper232 is offline   Reply With Quote
Old 01-17-2006, 11:13 AM   #5 (permalink)
Member Number: 37226
i agree with td1042k ....these parking brakes are as useful as hemoroids....lol
spoolin05srt is offline   Reply With Quote
Old 01-17-2006, 05:12 PM   #6 (permalink)
Senior Moderator
stowaway's Avatar
Member Number: 3286
if you don't do e-brake slides then it works just fine. I use it every time I park, never used it to slow me down, and it still holds me on my steep driveway.
Old 01-17-2006, 05:21 PM   #7 (permalink)
Overcome's Avatar
Member Number: 24451
Trader Rating: (20)
Been two years and I finally need to adjust it.
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
– Evan Michael Tanner 1971-2008
Old 01-17-2006, 05:49 PM   #8 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (40)
they come in handy if you ever tried to drag race...... you use it to do the burnout.... so yes i can see where adjusting it helps....
"When the turbo spins, the bullshit ends"
d_fl8ted1 is offline   Reply With Quote
Old 01-17-2006, 06:51 PM   #9 (permalink)
WaLkInGaLoNe's Avatar
Member Number: 27922
Drum brakes as far as a parking brake are the best really. There is more surface area on the shoes to grab the "drum" area on the rotor. They are really easy to adjust and honestly you'll never replace the shoes, I never replaced my brake shoes on my ford tempo and I had the car 3 years. It will honestly take you more time to jack the car up then adjusting the parking brake.
WaLkInGaLoNe is offline   Reply With Quote
Old 01-19-2006, 02:09 PM   #10 (permalink)
Hypurr's Avatar
Member Number: 9644
WHy don't you check on a 2001 Neon forum. Since that is what you used fro your swap.
Or are you full of Shart?
Hypurr is offline   Reply With Quote
Old 10-08-2006, 11:50 PM   #11 (permalink)
Member Number: 45649
I adjusted my parking brake and it works great now. Pull the wheel, take off the brake caliper and then the rotor. You will see a small gear like adjuster. turn it slightly. this will spread the shoes a bit. it doesn't do "that" much, but it does enough to keep the car from sliding down the hill
Good luck
myjagis2fast is offline   Reply With Quote
Old 10-10-2006, 06:19 PM   #12 (permalink)
MASSSRT's Avatar
Member Number: 23778
I've adjusted mine twice like this, takes 2 seconds and works great
11.60 @ 129.8
LIFTING, NO BURNOUT, FULL INTERIOR
MASSSRT is online now   Reply With Quote
Old 10-10-2006, 06:22 PM   #13 (permalink)
MASSSRT's Avatar
here : (in detail)
ADJUSTMENT
NOTE: The parking brake shoes used in the drumin-
hat park brake system do not automatically
adjust to compensate for brake shoe lining wear.
Therefore, it is necessary to manually adjust the
parking brake shoes.
(1) Verify the parking brake lever is in the
released position.
(2) Raise the vehicle. (Refer to LUBRICATION &
MAINTENANCE/HOISTING - STANDARD PROCEDURE).
(3) Remove the rubber plug from the adjusting
hole in the disc brake caliper adapter.
(4) Adjust the parking brakes. Use the first bullet
point for the adjustment of the left side parking
brake shoes. Use the second bullet point for the
adjustment of the right side parking brake shoes.
˛ Insert a medium size screwdriver through
adjustment hole in the left backing plate. Position
the screwdriver against the star wheel on the parking
brake shoe adjuster. Using the screwdriver,
rotate the star wheel downward until a slight drag is
noticed when turning the rear tire and wheel assembly.
Then, using the screwdriver, slowly rotate the
star wheel upward, backing off the adjuster, just
enough to allow the rear tire and wheel assembly to
rotate without the parking brake shoes dragging. Do
not back off the adjuster star wheel more than two
clicks past the point of no drag. The parking brake
shoe-to-drum clearance is now properly set.
adjustment hole in the right backing plate. Position
rotate the star wheel upward until a slight drag is
star wheel downward, backing off the adjuster, just
not back off the adjuster star wheel more that two
(5) Install the rubber plug in the adjusting holes of
(6) Lower the vehicle until the rear tires are just
clearing the floor.
(7) Reach inside the vehicle and fully apply and
release the park brakes two times after adjusting the
(8) With the parking brake lever in the fully
applied position, attempt to hand rotate each rear
tire and wheel assembly to ensure that the parking
brake shoes are working.
(9) With the parking brake lever in the released
position, hand rotate each rear tire and wheel assembly
to ensure that the parking brake shoes are not
dragging.
Page generated in 0.27052 seconds with 13 queries
