ACR Lowering Woes
So im trying to remove the springs from my ACR struts, The how-to sticky says to use a 10 mm 1/4" socket and extension inside of a 13/16" spark plug remover. well.... the top nut on the shaft itself where the adjusting knob is cannot fit a 10 mm.
Its flat on 2 sides and curved on the other two. ive tried several metric and standard sockets to get it to grip... but to no avail. how the heck am i supposed to get the inside nut to loosen when the shaft keeps spinning?
" Raise boost till you blow the head gasket(or crack pistons), then back off slightly."
