Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Coolingmist
Old 04-23-2007, 07:00 AM   #1 (permalink)
Member Number: 8193
Default Thank You
David I just wanted to say thanks. I ordered a valve last week on Wen. got a confirm from fedex that evening that it had been shipped and Sat the fedex guy walked down my driveway just as I was running the new wi line. Could not have worked out any better than if I had yelled from under the car, "Dave. Hand me that valve." And it was placed in my hand.
For the best cusomer service and quickest shipping.... Thanks
John
Old 04-23-2007, 04:11 PM   #2 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
No problem, Im glad you got your valve. I gave you our new fittings
CM
Old 04-23-2007, 08:48 PM   #3 (permalink)
Member Number: 8193
CM
Yeah I like . I also see that the valve is somewhat servicable. I used a 1/4 to 1/8 reducer at the out end and it is now my nozzle holder as well. Very nice.
I was origionaly planing on putting the S-HSV before the nozzle, but after seeing the picture I'm not sure I will have the room. Would you see any problem with mounting the S-HSV on the pump and leaving the check valve at the nozzle. I have a barn-yard leangth of 1/4 nylon hose that runs from the trunk to the where the pump is to the IC where the nozzle is. So something needs be there to keep the fluid from running out into my IC.
Any thoughts?
Old 04-24-2007, 06:34 AM   #4 (permalink)
Trader Rating: (51)
CM
Any thoughts?
You can mount the S-HSV at the pump or near the nozzle. The pump solution will be easy, which is why our kits will come that way. This brings a good point, you dont use a checkvalve with the S-HSV, it needs to be completely eliminated. You do need a water filter though.
I'm going to need to talk to you later in this week about your setup.
CM
Page generated in 0.18992 seconds with 11 queries
