Question for CM
I wanted your opinion on something, I have seen some negative comments on using the 150 psi pump with a direct port system. Some have said that its not enough pressure and it just dribbles instead of spraying like it should.
My question to you is, do you think this is correct or did the person saying this possibly have an issue other than what was stated? Do you feel that 150 psi is enough pressure for a 4 cylinder direct port with m2 nozzles?
Or do I really need to upgrade to the newer 200/250 psi pump? I will take your word as the final say on the issue.
