Quote: Originally Posted by BTR
Thanks alot bud the new pump works...
although it did take quite some time to prime (more than 2 minutes) I did the same with the other pump for 3 mins and it still didnt prime.
for some reason my pump isnt spraying no matter what boost i'm at, when i hook it up to the battery directly the led turns on and the pump works but perhaps the relay isnt working?
Which way to do I turn the knob to turn the boost up/down...
the boost switch turns counter clockwise for lower, clockwise for higher. its set at 10 psi. I would check the electrical connections make sure its wired correctly.
CM
