Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Coolingmist
Old 07-07-2008, 03:14 PM   #1 (permalink)
mcduuuugal808's Avatar
Member Number: 40516
Default Only capable of using 1/2 gallon before losing prime.
ok, tell me if you have ran into this before, I have the STG3 trunkmount kit.
I can only run the tank 1/2 gallon from full until the kit some how loses its prime, I then will have to fill it up, prime it, then it will be ok again. but it's always at the same level when this happens. heres a pic to show the level.
You should try walking a mile in your enemy's shoes, you'll be a mile away from them, and you'll have they're shoes!
mcduuuugal808 is online now   Reply With Quote
Old 07-07-2008, 06:10 PM   #2 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
the only reason it would lose prime is that air gets in the line. If it swooshes around that could cause that problem. I must point out that this is not normal. I would check everything carefuly.
David
Page generated in 0.16271 seconds with 11 queries
